It is currently Sun Dec 17, 2017 9:11 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 8615 posts ]  Go to page Previous 1393 394 395 396 397575 Next
PostPosted: Thu Sep 20, 2012 9:27 pm
HammerTime2: Yep.. I've climbed/dropped 30% grades on my MTB and I'd say this was worse.
The data from Strava perhaps isn't worth much, but shows there's a pretty steep section of road.
http://app.strava.com/rides/22587328#z8874|8920
I may be wrong.. maybe if somebody with less fatigue (I'm knackered :-) ) could calculate the real incline of the first section of this road using this map. The increase in elevation is 5 metres per line. Scale is also indicated at the bottom.
Link to map: http://kart.finn.no/?lng=10.69311&lat=59.83008&zoom=20&mapType=finnvector
PostPosted: Fri Sep 21, 2012 7:50 am
subic bay, philippines
PostPosted: Fri Sep 21, 2012 10:36 am
Well I found it on google street view: http://goo.gl/maps/6ttpj
It does look horrendously steep, That's all I can say.
Edit: this link to streetview shows how ridiculously steep that road is: http://goo.gl/maps/YD5LU
PostPosted: Fri Sep 21, 2012 11:43 am
CarpetFibre: Yeah.. Haha. That last link does serve some justice to the steepness :-) Add to it that the road on the left hand side is fairly steep aswell, probably 8-10%.
PostPosted: Fri Sep 21, 2012 12:29 pm
PostPosted: Sat Sep 22, 2012 1:26 am
PostPosted: Sat Sep 22, 2012 1:48 am
The Shuttle's swan song over JPL
PostPosted: Sat Sep 22, 2012 5:33 am
@Esterhas.. very cool
PostPosted: Sat Sep 22, 2012 8:23 am
Epic picture!
My current ride
PostPosted: Sat Sep 22, 2012 8:28 am
@Esterhas my hometown and some of my favorite mountains to ride in
PostPosted: Sat Sep 22, 2012 10:40 am
Where's JPL? :noidea:
PostPosted: Sat Sep 22, 2012 11:36 am
Guys, think we can help this poor chap out?
viewtopic.php?f=3&t=107438
VeloKicks
The Gram
The Men of Steel
PostPosted: Sat Sep 22, 2012 1:12 pm
Caltech's Jet Propulsion Laboratory in Pasadena, California (USA) , just Northeast of Los Angeles.
http://www.jpl.nasa.gov/news/news.php?release=2012-299
http://en.wikipedia.org/wiki/Jet_Propulsion_Laboratory
PostPosted: Sat Sep 22, 2012 3:28 pm
http://app.strava.com/rides/22587328#z8874|8920" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I might have the wrong road here but MapMyRide shows elevation on mapped roads. You can give it a section of road and it will give you back elevation with gradient.
If you give it too long of a road it will average it out by the way.
But this road is short enough.
This is how to calculate
Percent slope =
%m = (rise/run)*100
%m = (100ft./1320ft.)*100
%m = (.0757)*100
%m = 7.6 %
PostPosted: Sat Sep 22, 2012 4:18 pm
Let d be the distance along the road, and e be the elevation gain. Then the percent grade is 100*e/[square root of (d*d- e*e)] . Note that d is the hypotenuse of the right triangle with sides e and square root of(d*d - e*e). Note that in stella's formula above, e is the rise, but square root of (d*d- e*e), not d, is the run. The run is not shown on the map, and needs to be computed (as above or by mathematically equivalent procedure).
If you want to solve for the elevation gain needed for 40% grade over a given distance along the road, d, the answer is d*sin(arctan(.4)) . So for example, for a distance along the road of 500m, an elevation gain of 185.7m (185,7 european style) corresponds to a 40% grade. You can get the answer in google by doing a "search" on 500*sin(arctan(.4)) , even if you don't know anything about trigonometry. So you'd need to cross 37 contour lines of 5m elevation difference over the span of 500m distance along the road to correspond to 40% grade.
I'll leave it to someone else to identify a suitable section of the road and count the contour crossings and corresponding distance along the road on djm's map. Then plug into the formula in the first paragraph, and there's your answer (presuming the map, with its elevation contours, is accurate).
Please note that the approximation of percent grade being 100*e/d becomes more and more inaccurate as the grade increases (not bad for 6% grade, not good for 40% grade). Using this approximate method for an elevation gain of 185.7m over a distance along the road of 500m results in (an approximate) grade of 37.1%, as opposed to the actual grade of 40%.
There are no new unread posts for this topic. Attachment(s) 2017 On the road today
[ Go to page: 151 52 53 54 55 ]
94824
Sun Dec 17, 2017 7:35 pm
banik69 View the latest post
Frankie - B
34
3258
Fri Feb 24, 2017 12:30 am
nobuseri View the latest post
There are no new unread posts for this topic. Attachment(s) Today in things that suck
[ Go to page: 1 2 3 4 5 ]
kfreytag
63
6099
Sat Dec 31, 2016 12:48 am
kfreytag View the latest post
There are no new unread posts for this topic. Alloy road bar with a drop curve like the ENVE SES Aero Road Bar?
VTR1000SP2
11
1710
Wed Oct 04, 2017 4:08 pm
cwdzoot View the latest post
Users browsing this forum: mrlobber and 7 guests
