It is currently Wed Jan 24, 2018 1:06 pm
Post new topic  Reply to topic  [ 3 posts ]
 Post subject: Tuning a carbon saddle
PostPosted: Wed Sep 22, 2004 10:30 pm
I have a Sella San marco Era Composite and the area behind the nose (where most my weight is) is a little stiff. This saddle is a straight backed saddle. Has anyone tuned thier saddle by drilling hole in the shell? The area where it is stiff and straight could use some softening. Maybe if I drilled some holes in it, it would flex there. Would the holes tend to tear? It's a carbon fiber shell with a thin padded cover. I would only be drilling the shell.
 Post subject:
PostPosted: Thu Sep 23, 2004 2:47 pm
it would be more easy if you posted some pix of the saddle with kind of sketches on it, showing what area exactly you want to soften or even where you plan to drill holes.
generally speaking, you can drill carbon BUT it depends quite a lot on material thickness, your "drilling skills" (by wich i'm also talking of your equipment) and the loads wich the weakened structure still must take.
 Post subject:
 Post subject:
PostPosted: Thu Sep 23, 2004 2:48 pm
and not to forget you should seal the cuts!
There are no new unread posts for this topic. Attachment(s) New Saddle: Selle Italia Carbonio Flow vs San Marco Aspide Carbon vs San Marco Mantra Carbon
3Pio
35
3431
Fri Oct 27, 2017 9:48 pm
3Pio View the latest post
There are no new unread posts for this topic. eBay carbon saddle?
addictR1
Sat Dec 02, 2017 7:38 am
addictR1 View the latest post
There are no new unread posts for this topic. Carbon saddle ate my shorts ?
ukracer
10
1251
Sun Oct 08, 2017 10:59 pm
Johnny Rad View the latest post
There are no new unread posts for this topic. Attachment(s) New Bontrager xxx carbon saddle
Stormtrooper
24
4658
Sun Dec 31, 2017 9:09 am
Frankie - B View the latest post
There are no new unread posts for this topic. Di2 fine tuning problem
havana
12
1305
Mon Mar 27, 2017 10:11 pm
agravic View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], Hennesy, PinaF8, rainerhq, TurboKoo and 17 guests
