It is currently Thu Jan 18, 2018 1:29 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Aug 11, 2004 3:18 pm
Administrator
I'm currently writing a paper about training and I'm looking for a name of a vo2 max test that as done on a cycle. Maybe also some extra info on the test. Like how the test is done and the products used.
Who can help me?
{USERNAME} wrote:
 Post subject:
PostPosted: Wed Aug 11, 2004 3:54 pm
I think there is a test called 'ramp test' that can be done with a mask conected to a tube that measures your vo2 consumption and therefore your vo2 max.
 Post subject:
PostPosted: Wed Aug 11, 2004 4:17 pm
Administrator
Does this test increase the amount of watt you have to give in steps of for instance 10?
Does anyone know this "ramptest"?
 Post subject:
PostPosted: Thu Aug 12, 2004 1:50 am
Yes, I have had the test done about 6 times in the past year or so. Basically you start out at 100w, and the operator increases your wattage on an ergometer by about 50w every 2 minutes until failure. You are wearing a nose clip, and an oxygen meter that is connected to a computer to calculate your vo2 max.
 Post subject:
PostPosted: Thu Aug 12, 2004 8:53 am
Administrator
ok, thanks!
 Post subject:
PostPosted: Thu Aug 12, 2004 8:56 am
Yes, I know it. It is known in The Netherlands as a "Maximaaltest". The protocol (the increases in Watts and the timeframe) varies a lot. Also the test can be done with breath measurements trough a mask, or measuring lactate in the blood at each step (Blood taken from an ear or finger).
Most books on training (the serious ones...) discuss these kinds of tests. For instance, check out "The mountainbikers' training bible" by Joe Friel. You also might want to search in the trainings sections of www.cyclingnews.com and www.velonews.com.
 Post subject: VO2 Max Testing
PostPosted: Mon Sep 06, 2004 5:39 pm
Trainsmart is a relitively new company but with years over 20 years of testing knowledge and facts and data.
Trainsmart is the only company that I know of that can actually bring the test to you in your own home.
Trainsmart uses new technology and the latest scientific research.
Using a book and crunching numbers based on age, formulas, tables is just pure guesswork. There are many ways to predict VO2 Max but only 1 actual way to be 100% accurate! Get a proper test done under laboratory conditions. This means wearing a mask during the test to analyse what you are breathing in and out and how much oxygen your body is using during the test!
www.Trainsmartuk.uk.com
 Post subject:
PostPosted: Mon Sep 06, 2004 6:25 pm
Administrator
Sounds like this is your own company!
But thanks to all who gave me help. I finished the paper!
Thanks a lot!
 Post subject: VO2Max
PostPosted: Wed Sep 08, 2004 11:33 am
Whoops... the webpage should read... www.trainsmart.uk.com
There are no new unread posts for this topic. Campagnolo SR ITA BB cups installation method
karhu
14
852
Mon Jul 03, 2017 11:15 pm
AJS914 View the latest post
Users browsing this forum: sib and 3 guests
