It is currently Tue Dec 12, 2017 9:41 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Sun Jun 15, 2003 12:03 am
Anyone experience problems with the left/right bushings joining the top of the sid shock to the pivot arm on the 2003 NRS? This frame is has only been ridden once and already has play in the bushing at this location. I've tightened it as far as the hex will go and still loose when pulling up and down on the seat while holding the back wheel with my foot to the ground.
Thanks
 Post subject: NRS Bushing play
PostPosted: Tue Jun 17, 2003 7:07 am
Exactly where is the play? at the actual point of attachment of the shock? or on the outside pivot? I believe the only pivot point on the frame that doesn't have sealed bearings is at the shock. It is possible to overtighten and crush a pivot (see the manual for torque settings). Mine is rock solid there, nor have I seen what you've described at the shop where I work, and we sell a lot of NRS's. Sounds like you might be missing a spacer or something. I would let the giant dealer where you bought it at take a look at it ASAP as you dont want to sideload that shock. Should be taken care of without issue.
There are no new unread posts for this topic. Full suspension concept gravel
wheelsONfire
Sat Aug 12, 2017 5:52 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Cervelo C3 with 100mm suspension fork - Gravel for real!
andreszucs
Fri Sep 01, 2017 4:06 pm
andreszucs View the latest post
There are no new unread posts for this topic. Lightest dual suspension Mountain Bike for Kids
carbonXScycles
Fri Oct 27, 2017 12:19 pm
JScycle View the latest post
There are no new unread posts for this topic. Want: adapt the Naild R3act-2Play philosophy to XC race rear and front suspension
in MTB
milesthedog
33
2613
Wed Aug 16, 2017 2:45 am
silvalis View the latest post
There are no new unread posts for this topic. 6.87kg Full suspension Scott Spark With Full List
in MTB
SK5
19
1141
Mon Dec 11, 2017 7:42 pm
bikemaniack View the latest post
Users browsing this forum: No registered users and 10 guests
