10 speed chain options
nzkiwiguy
by nzkiwiguy
I am building some new rides as purely ten speed dura ace. Until now I have used 9 speed cassette's and chains with some of the new 7800 components.
I have used and love SRAM chains, but they don't make a 10 speed one as of yet (Interbike release I was told)
What chain's should I look at. I am not a fan of the Dura ace chain, although I can't really give you a good reason why.
Have heard mixed reports on Wipperman stainless. Know nothing about KMC or the smaller brands.
Love your thoughts
bobalou
by bobalou
nzkiwiguy wrote:I am building some new rides as purely ten speed dura ace. Until now I have used 9 speed cassette's and chains with some of the new 7800 components.
Love your thoughts
Maybe this will help:
http://weightweenies.starbike.com/forum ... php?t=2275
But, if I were you I"d only use the 7800 chain. Shimano uses 10-speed cassettes even more narrow then campy.
nzkiwiguy
by nzkiwiguy
bobalou
I read this, thanks. It does help but I am after some real world experience.
Also if it matters one bike will be all Ti cogs and rings. The other is standard shimano
Superlite
by Superlite
I wasn't a fan of the 9 speed chains, as I went though those like water. 4 or 5 last year.
The new 10 speed chain however is the bomb! over 5,000 miles and the chain wear indicator says it's only at .50 !!! They are bombproof!
Most of the credit goes to the chain being narrower of course, the narrower the pins the less they will deform over time due to an effect of increased stiffness.
Don't worry about the new DA chain, get it and ride it. They work like a chain should.
divve
by divve
If it's really .5% it's worn :lol:
Superlite
by Superlite
nah, your supposed to replace at .75, but I guess if you wanted to end a little early you could.
Still, 5,000 miles and .5 is awsome. Old 9 speed chains, maybe half that. :shock:
nzkiwiguy
by nzkiwiguy
Thnaks Superlite.
How's your crank coming?
Superlite
by Superlite
Thnaks Superlite.
:lol:
It's not.
Materials are too hard to come by and the suppliers won't sell me the quantity of Ti that I need (to little). It's all designed and ready to be made, but without the Ti tubing there is no cranks.
I'm looking into alternative materials, but none will be nearly as light as the Ti ones would have been. Chromoly is the next best bet.
The Reaper
by The Reaper
5000 miles on a 7800 chain , What on a windtrainer . I have replaced dozens of cliants chains in the last few months,the best seems more like 5000 KM . Whats miles anyway i though we went to the metric system years :?: Replacement for this chain :?: I have'nt found one yet but Ti would be nice if we did'nt have a externale with problem , but we DO !
Superlite
by Superlite
5000 miles on a 7800 chain , What on a windtrainer . I have replaced dozens of cliants chains in the last few months,the best seems more like 5000 KM . Whats miles anyway i though we went to the metric system years Replacement for this chain I have'nt found one yet but Ti would be nice if we did'nt have a externale with problem , but we DO !
Ok?
I have 5,000+ miles (8,000km for the metrically inclined) on real road use and racing.
Another factor you should consider is rider type, and body weight. I weigh 138lbs, so I don't stretch the chain as much as say one of you clients who may or may not be much heavier then I am.
jer
by jer
The SRAM PC-89R hollow pin chin is 6.2mm wide. The wipperman 10 speed chains are 6.2mm. Campy 10 is 6.1 and DA 10 is 6.1mm.
Dura-ace 9 chains are 6.6 and Campy 9 chains are 6.8mm
The only reason you can't use the 89R hollow pin for 10 speed is the sram power link is 6.6mm wide. If you can reuse a hollow pin it will work fine for ten speed.
BTW: this is only true for the 89R hollow pin.
the 89R with out hollow pins is 6.7mm
pc99 hollow pin is 6.4mm
and pc99 w/o hollow pins 6.9mm
popawheelie
by popawheelie
How about the Wipperman nickel plated 10 speed. I was thinking of putting this chain on my Campy drivetrain. I don't need Stainless but would like the Wipperman with the removeable link.
