It is currently Sun Jan 21, 2018 6:11 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Jun 10, 2004 4:59 pm
Any suggestions on the simplist way of polishing scratches out of titanium. I'm not looking at getting back to the original shine/finish - just getting rid of some unsightly abrasions.
 Post subject:
PostPosted: Thu Jun 10, 2004 5:14 pm
3M makes a line of automotive finishing abrasive paper in grades as fine as 2000 grit. You should be able to duplicate the factory finish with these, testing on the BB shell or a piece of scrap.
The abrasive is Silicon Carbide which is a very sharp and hard abrasive, capable of fast action on Ti. The paper is also used wet which helps the finish process. With 2000 grit, the finished look is a medium polish, not mirror though. You need cerium oxide to bring out a mirror shine.
 Post subject:
PostPosted: Thu Jun 10, 2004 5:17 pm
Just find a metal polisher, you'll be better off. Polishing metal, esp. a hard metal like Ti can be very difficult. I personally don't think it's something t odo yourself, unless you have knowledge on the subject and proper buffing equipment.
If its just a few scratches you want buffed out it probley won't set you back more then $20. I had my old frame polished for just $80, looked friggin awsome with the mirror finish. Have a professional do it, and save the headachs.
 Post subject:
PostPosted: Fri Jun 11, 2004 5:25 am
I've had the best luck with scotch brite pads. You can create a great finish with them. Seven Cycles recommends scotch brite pads for replenishing the factory finish to their frames.
 Post subject:
PostPosted: Fri Jun 11, 2004 5:39 am
Jewelers Rouge on ScotchBrite pad or polishing cloth.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
There are no new unread posts for this topic. New Fork for the Look 585. Suggestions?
Catagory6
Thu Dec 07, 2017 3:41 pm
Svetty View the latest post
There are no new unread posts for this topic. Suggestions for finishing bar tape ?
wobbly
22
2011
Sat Jul 15, 2017 6:11 am
Nefarious86 View the latest post
There are no new unread posts for this topic. First Power meter suggestions
[ Go to page: 13 4 5 6 7 ]
merser
91
8299
Wed Aug 02, 2017 5:38 pm
evan326 View the latest post
There are no new unread posts for this topic. Lightweight Trackframeset suggestions
JLS
34
2535
Wed Jan 25, 2017 5:19 am
mpulsiv View the latest post
There are no new unread posts for this topic. Birthday build.... looking for suggestions
jever98
7
846
Mon Mar 06, 2017 10:35 am
jlok View the latest post
Users browsing this forum: benjaminm3, Cervelolite, ewwhite, hcgaloi, JayUK, NYCPrynne, themidge, tonytourist and 32 guests
cron
