It is currently Sat Oct 21, 2017 8:05 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
 Post subject: Cranck length
PostPosted: Mon Jun 07, 2004 3:17 pm
Which is the ideal cranck length for an inside leg of 92cm?
 Post subject: Re: Cranck length
PostPosted: Mon Jun 07, 2004 3:22 pm
I have 96 cm inseam and use 175 (mtb),177,5 (road) and 180 (road)mm....
I have two different Bioracer readings one says I should use 177.5 and one says 180 mm. I would reccomend you to get measured it´s not only your inseam that counts also the lenght of your femoral bone.
If you want to play it safe get 175 mm.
 Post subject:
PostPosted: Mon Jun 07, 2004 4:29 pm
I have 91cm inceam (185cm tall). All cranks road/TT/CC/mtb are 175mm.
Samu @ www.signature.fi
 Post subject: Length
PostPosted: Mon Jun 07, 2004 11:56 pm
I have 93cm inseam, and 1800 cranks on the MtB, Road and track bikes. Looking for some 182.5s or 185s for the TT bike (I'm currently a set of cranks short).
Also measure your Femur/Tibia ratio the higher the number the longer the crank (male average is 1.1).
Success is how far you you bounce back up after being knocked down
 Post subject:
PostPosted: Tue Jun 08, 2004 3:59 am
I measure my inseam at 92 and my femur/tibia ratio at 1.225 i am running 172.5's do you guys think i should go larger than 175?
Zac
 Post subject: cranklength
PostPosted: Tue Jun 08, 2004 8:26 am
I would say 175 mm is a safe bet. Furthermore longer cranks in carbon are quite hard to get (only FSA, Stronglight). When Aluminium I guess 177.5 would be a good choice. All depending on the type of rider you are, if you're really fast in sprints don't go larger than 175 since longer cranks don't work.
 Post subject:
PostPosted: Tue Jun 08, 2004 9:20 am
If you want longer carbon cranks you better hurry. Stronglight decided not to make 177.5 and 180 mm availiable (Pulsion) so even if it´s listed many places online and in catalogues, you can´t buy them.
FSA sold very few 177.5 and 180 mm cranksets and have therefore discontinued production of sets longer than 175 mm they wont be coming in those lengths in the future. They have less than 50 cranksets in 177.5 mm in stock and wont be producing more. You can buy them directly from the factory, just write them.
 Post subject:
PostPosted: Tue Jun 08, 2004 10:20 am
177,5 and 180 are merely available. Just stupid! The manufacturers stop making them because they think there's no demand for them but there IS! The only problem is you can't find them at a reasonable price! I'd love to buy 180 mm Ultegra's but Shimano doesn't make them :evil:
Whow! That's a pretty damn nice garage door!
 Post subject:
PostPosted: Tue Jun 08, 2004 7:53 pm
Here are a couple of links that discuss crank length. The "Kirby Palm Method" http://www.nettally.com/palmk/crankset.html suggests that i ride 180mm cranks. I have an 84 cm inseam. That sounded long to me but I experimented with it for a couple of months and i found that my power output was increased but my useful rpm range was reduced. i.e. They felt more efficient from about 85-92 rpm but less efficient when pedaling faster than 92rpm or slower than 85rpm. This was better for climbs and time trials because it is easy to stay in that narrow range. However, in mountain bike races, criteriums, and road races I found I was using more rpm range to respond to the constant accelerations and changes in pace. I am now using 175mm which corresponds roughly to the "Gallic Coincidence Factor" http://www.cranklength.info/cranks.htm for my leg length, and I find them to be a good compromise. (I had been using 172.5 for years.)
Neither of these formulas takes into account riding style (spinner or gear masher) which is probably related to your fast-twitch/slow twitch muscle fiber ratio and your aerobic capacity, so they are a good place to start but certainly not the definitive word on crank length. Also, it has already been mentioned but femur length is actually a more important factor than leg length in determining crank length but I think femur length is quite difficult to get an accurate measurement for.
If anyone is interested in the relationship between foot speed and crank length I made a simple spreadsheet that displayed foot speed at different rpm with different length cranks. I can try to post it, but I have never tried to attach an excel file before so I don’t know if it will work.
 Post subject:
PostPosted: Tue Jun 08, 2004 7:58 pm
You might consider Zinn Cycles custom cranks:
http://www.zinncycles.com/cranks.aspx
He's got good info in cranks there also.
 Post subject:
PostPosted: Tue Jun 08, 2004 8:04 pm
Wow 220 mm cranks.... Try turning while pedalling with those...
 Post subject:
PostPosted: Tue Jun 08, 2004 8:59 pm
According to the X 0.21 formula I (96cm inseam) need 202 mm cranks :shock:
When using the X 0,216 I should have 207 mm :shock:
Actually I ride 175's now........
 Post subject:
PostPosted: Tue Jun 08, 2004 9:04 pm
After reading this I'll change to 175mm (inseam 172.5mm)
I'm currently using 172.5mm, with no problems yet, but I think 175 will be more efficient. I like the lower rpm, however, I may not use something bigger than 52/14, so sometimes it's spinning. I think 175 will be a safe bet (not losing to much speed and a bigger power output)
 Post subject:
PostPosted: Tue Jun 08, 2004 10:23 pm
If I were you I'd try some longer cranks. You'd get noticably more power I bet.
 Post subject:
 Post subject:
PostPosted: Tue Jun 08, 2004 10:49 pm
Placed an ad on a Dutch cycling forum and 10 minutes later I got an email from a guy who wants to sell me a pair of 180 mm D-A's :D
There are no new unread posts for this topic. srm crank length
simoncx
7
302
Tue Oct 10, 2017 4:23 pm
simoncx View the latest post
There are no new unread posts for this topic. Length of the chain?
TonyM
9
997
Sat May 20, 2017 9:24 pm
boots2000 View the latest post
There are no new unread posts for this topic. Reach and top tube length
cmcdonnell
9
1135
Sat Mar 11, 2017 4:44 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Crank length confusion
Greatestalltime
19
1616
Tue Jul 18, 2017 1:46 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Attachment(s) Chain length for running both 12-25 and 12-29 Campy
Alexandrumarian
Fri Aug 25, 2017 7:57 am
TobinHatesYou View the latest post
Users browsing this forum: alanmclean, Bing [Bot], micky, shk1, zoki76 and 35 guests
