It is currently Fri Sep 22, 2017 12:12 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu May 27, 2004 7:20 am
Campa's catalogue shows only Record steel and Veloce are only options in that size. I could use alloy cassette if there are any well shifting one? Tiso seems to be not one.
Wheels are Lightweight's on Record cassette hub.
Is Record steel only real option?
Thanks, Samu
Samu @ www.signature.fi
PostPosted: Thu May 27, 2004 9:07 am
Samu Ilonen wrote:
... Tiso seems to be not one...
I would personally rate Tiso's cassette over the rest, but I also hear that Campag shifts better. I think if you have the system tuned perfectly, Tiso works perfectly.
www.tisobike.com
I'm getting their Titanium Cassette on my new bike :D
 Post subject:
PostPosted: Thu May 27, 2004 11:48 am
I think I have to pass Tiso. I just don't want test it and then it may not work well...Then I have to stick on Campa?
Having 12-13-14-15-16-17-18-19 and 21-23 would be nice.
On time trials linear 12-19 would save seconds if wind is strong. And 12-23 would be nice on group rides.
I use 54 on TT and 53 on road. Sad that easyest and only now is to get Veloce. ~250g...but better pay weight penalty than lose speed. I think I will rob half cassette from my current Chorus (12-25) 12-17 and rest comes from Veloce IF Record can not be found....If I could buy some (4) alloy cassette rings from TA, Tiso etc 18-19-21-23...then I could use Chorus 12-25 cassette and have light, stong system? 12-17 are most used and on hardest loadet gears.
And in winter I could use those unuset 19-21-23-25 in my studdet cyclocross bike. In snow it's not very much use smaller gears than 39/19.
Is it bad idea?
 Post subject:
PostPosted: Thu May 27, 2004 12:52 pm
You also have Cycle Dynamics Ti cassette wich you can customize and change cogs individually.
I've been waiting almost a month for mine...and still don't have it.
 Post subject:
PostPosted: Fri May 28, 2004 12:08 am
...maybe I'm not understanding the question properly. Are you asking whether the standard Record Ti/Steel 12-23 is available? If so, they are. I bought 2 about two months ago.
 Post subject:
PostPosted: Sun May 30, 2004 5:24 pm
Q:
Yes, is it sold common and is there ANY good alternatives?
 Post subject:
PostPosted: Sun May 30, 2004 8:33 pm
Yes, the Record 12-23 is commonly available, in steel + ti, not in all ti.
You can also make any custom range with Miche alloy, lighter and less expensive than ti, not so durable though.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Sun May 30, 2004 8:59 pm
Can Miche,TA, Tiso cassette ring get separately?
It would be easy to upgade Chorus 12-25 to 12-23 with 4 biggest rings, 18-19-21-23. May be not very expensive and should last for awhile...
 Post subject:
PostPosted: Sun May 30, 2004 9:14 pm
Samu Ilonen wrote:
Q:
You can always use Marchisio's. They're not superlight but shift well. And they can be combined any way you like. Price for a 10speed is around 100Eur
Martin
Snowman and Strong Walker
Scott Sc
my old stuff
my new stuff
 Post subject:
PostPosted: Sun May 30, 2004 9:48 pm
Miche cassette rings are available separately. There is a source here in Southern California, but from Finland I don't know the nearest dealer....ShockBike in Italy is good.
 Post subject:
PostPosted: Mon May 31, 2004 6:35 am
Any webb stores that sells these cassette rings separetely? I could order them then...
 Post subject:
 Post subject:
PostPosted: Mon May 31, 2004 6:45 am
Since you're in Finland, I would recommend you contact Wiggle, in England:
http://www.wiggle.co.uk/?Manu=Miche
But just do a web search for "Miche cassette" or "Miche cassettes", you'll find stores in Belgium, France, Denmark, etc.
There are no new unread posts for this topic. When will Campa release EPS 2.0?
vlastrada
Mon Mar 06, 2017 3:50 am
Seedster View the latest post
There are no new unread posts for this topic. Campa Ultratorque issue
marshalus
7
853
Wed Mar 29, 2017 12:44 pm
marshalus View the latest post
There are no new unread posts for this topic. Need help on power2max Type S Campa 2015
poppiholla
7
494
Sat May 27, 2017 10:35 pm
poppiholla View the latest post
There are no new unread posts for this topic. Shimano 685 reach vs Campa Chorus
micro553
Tue Jan 17, 2017 9:35 am
micro553 View the latest post
There are no new unread posts for this topic. Shifting Sram chainset compact on Campa groupset
Body
Thu Apr 13, 2017 3:07 pm
Body View the latest post
Users browsing this forum: albertop07, fezi, Ginsterdrz, Hexsense, JScycle, Yahoo [Bot] and 37 guests
