It is currently Sun Dec 17, 2017 3:42 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
 Post subject:
PostPosted: Fri Aug 11, 2006 11:55 am
Yeah but 54x11 is a whole other ball game
 Post subject:
PostPosted: Fri Aug 11, 2006 12:21 pm
CAADHEAD wrote:
Can you be competitive racing with a compact crank? wouldnt you suffer in the sprints, I mean the top sprinters use 54 chainrings dont they?
Ivan Basso rode some of the mountain stages in the Giro with 50/36 compact crankset, and was still competitive I would say.
On flat stages for a top sprinter they need 53-11 or maybe even higher.
the ger
But the gearing all depends on the course and the type of rider, this bike was probably set up for climbing or maybe only set up for the camera.
 Post subject:
 Post subject:
PostPosted: Fri Aug 11, 2006 12:47 pm
I think it was 52/36
 Post subject:
PostPosted: Fri Aug 11, 2006 12:56 pm
Yeah, that's what it says here: http://www.velonews.com/tech/report/art ... 971.0.html
 Post subject:
PostPosted: Fri Aug 11, 2006 1:04 pm
Do some research on gear inches. Compact isn't just a fad. It's actually probably one of the greatest things since sliced bread since 10-speed was introduced. A 34/50 with an 11-23 cassette gives you a wider range of gearing with a higher top gear and a lower bottom gear than a 39/53 with a 12-25 and allows you to ride in one chainring for a broader range of cadence/power. Less shifting in the front means less chance of dropping a chain and more time moving the bike forward.
Not to mention the Weight Weenie side effect of having less material on the crank, thus resulting in a lighter crankset, if only just so.
I've done a lot of research into this for a number of reasons, but suffice it to say that while my current Pinarello has a 39/53, my Pegoretti is getting a compact. I might go with a 36/50 only because I don't need that low of a climbing gear where I am but that's besides the point.
View before posting!
Pegoretti Love #3: It's here!!!
 Post subject:
PostPosted: Fri Aug 11, 2006 1:39 pm
Pretty sure the zip tie (ref previous posts) is there so that 1)no one can jump on the bike and ride it away, and 2)no one can turn the cranks just to see them work. Happens all the time at bike shows and such...
 Post subject:
PostPosted: Fri Aug 11, 2006 2:27 pm
Any idea where I can get that 36 tooth chainring? I'd like to change the 34 that came on my Time ASX.
 Post subject:
PostPosted: Fri Aug 11, 2006 3:40 pm
I don't know why they are now showing these pics, but they are not new. These were from a presentation done several months ago.
The zip tie was there because there were no bearings in the cranks yet....There was a supply problem with the bearings.
Also as for it being a compact, orginally,(and when these pics were taken) it was only going to be available as a compact, with different rings. However, after some rethinking, they decided to do a 130BCD in addition to the 110. The JJ riders will be getting the 130BCD, that is if the crank ever actually become available.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
 Post subject:
PostPosted: Fri Aug 11, 2006 3:42 pm
Zero Gravity cranks are taking a bit longer to become available than originally expected.
No $hit, Sherlock... :roll:
- G. Digital K. Loco
 Post subject:
PostPosted: Fri Aug 11, 2006 3:44 pm
[quote="singlespeed"]Any idea where I can get that 36 tooth chainring? I'd like to change the 34 that came on my Time ASX.[/quote]
If your crank is 110 PCD, then TA make lots of nice rings. Ask your LBS or online.
 Post subject:
PostPosted: Fri Aug 11, 2006 3:49 pm
I was looking specifically for that coated Stronglight. Thanks though, I think I have it worked out now. :wink:
 Post subject:
PostPosted: Fri Aug 11, 2006 5:39 pm
wow! 17.5lbs in that spec?! i would say don't buy cane creek wheels, because according to the claimed weight of the frame and other components, the wheels must weigh about 5-6lbs to make that bike such a beast. :)
darn, and i was looking at buying a garneau bike. it's a shame.
 Post subject:
PostPosted: Fri Aug 11, 2006 6:36 pm
if you are an unfit fat bastard who cannot climb.
 Post subject:
PostPosted: Fri Aug 11, 2006 11:01 pm
Yea, that Ivan Basso using a 52/36 12-27 in the Giro is an unfit fat bastard who cannot climb. :roll:
 Post subject:
 Post subject:
PostPosted: Fri Aug 11, 2006 11:10 pm
Or have a high cadence.... or rarely use your largest gear... or don't see big gears but rather speed over an entire ride as a measure of how good a rider you are...
I'm a good climber, and a spinner. Compact appeals to me because I'm not a sprinter, and it is lighter. In about 1994 shimano did it with MTBs, I'm just surprised it has taken so long.
There are no new unread posts for this topic. Short Cranks
morganb
Sun Apr 09, 2017 3:16 am
Valbrona View the latest post
There are no new unread posts for this topic. Attachment(s) 165mm cranks
peted76
24
2625
Wed Feb 15, 2017 2:20 pm
WhyZ View the latest post
There are no new unread posts for this topic. mythic cranks
bm0p700f
Fri Sep 29, 2017 9:13 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Lightning cranks
nickf
16
2150
Tue Sep 26, 2017 11:53 pm
alcatraz View the latest post
There are no new unread posts for this topic. whats the difference in these red cranks
freshlegs
9
1206
Sat May 06, 2017 9:58 pm
rideintospace View the latest post
Users browsing this forum: 5DII, IrrelevantD, kookie and 23 guests
