Anyone used this tire?
520 Dan
by 520 Dan
Anyone ridden the schwalbe CX pro? I want to run Stans on my clincher CX wheels, and currently run Michelin Muds. Stans has advised against running michelin tires tubeless for cx and reccomended Schwalbe among others. I would also drop about 40 gms per tire.
Exar
by Exar
I've used the CX Pro wire-bead version as a training tire, they're a bit smallish for their advertised size (35C I believe, looks more like a 30C) but they perform well in the mud. I was not too thrilled with their cornering capabilities, which could have been because I had the cheap-o version.
Chains to the right!
elmar schrauth
by elmar schrauth
michelin runs with stans
i use them
schwalbe is good for very muddy conditions, better than michelin mud
elmar
simon
Resident Pro
by simon
schwalbes are on the small side, and the mud gets stuck in the thread and doesn't come out well. michelins are wider and you can ride them with less pressure because of that, and that gives a lot of grip as well. the thread is a bit similar to the traditional grifo thread, but with less place between the knobs.
520 Dan
by 520 Dan
Why do you think Stans was against using michelins?
elmar schrauth
by elmar schrauth
schwalbe -michelin
two years ago we had a race in luxemburg where it was possible to ride a steep uphill with schwalbe , but much more heavier with michelin
elmar
