It is currently Fri Dec 15, 2017 11:05 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Nov 13, 2017 1:11 am
My saddle to bb is also 68cm. The reason i didn’t buy 49 is it looks ill-proportioned. Way too small especially with dropped seat stay design and sloping top tube
PostPosted: Mon Nov 13, 2017 5:42 am
Yes, 52cm.
pesto13 wrote:
sun wrote:
Here is a shot of my bike. 662mm saddle height. Quite a bit lower than yours, but I've had a few bike fits and this is where we landed. 110mm stem with -12 degree rise. 10mm spacer on top of the headset cap. I could probably slam it, but I want some more rides outside to determine that.
https://1drv.ms/i/s!ApmgBMekbXRGgfozKfbb5Cx6jI7oJg
sun,
I think it looks nice!. Just to confirm that is a 52cm frame?.
PostPosted: Mon Nov 13, 2017 3:21 pm
I had same question last month, I am 170cm have a shorter torse with longer legs, my bb to top of saddle height is 698. In the beginning I choose 49cm Sagan version, because I want to be more aggressive. However, someone told me that the 49cm frame is too small for me, than I go to do some research about the geometry. I found that the geometry of 49 SL5 is larger than 49 SL6. So, If I choose 49 SL6, it is too small for me and look ill-proportioned. If I choose 52, I can put less spacer. Finally, I change 49 Sagan to 52 UL.
PostPosted: Mon Nov 13, 2017 4:36 pm
pesto13 wrote:
What stem size do you use?.
thanks,
105 mm.
Here's the bike I was refering to:
http://www.cyclingnews.com/features/pro ... ks-tarmac/
The geometry makes the new Tarmac indeed a bit shorter, so 52 might be not a bad bet too.
PostPosted: Mon Nov 13, 2017 6:44 pm
Resident master of GIF
the actual reach between 49 and 52 is the same. The difference comes in the seat post angles and head tube length.
i’m 5”7 and 29” inseam and use a 52cm. My saddle top to B.B. center is 703mm
Nate ★ Life , my tumblr joint
Instagramz
My Podcasts
PostPosted: Mon Nov 13, 2017 7:16 pm
Something interesting that I've noticed in this topic and in my experience with fits is that saddle height seems to have a bigger determination on what size bike fits than anything else, due to reach changing faster than stack because of seat angles getting slacker as bikes get larger (for most brands). My saddle height has gone up as I have switched to much shorter cranks to alleviate knee/hip issues and some bikes that used to fit me no longer do.
PostPosted: Tue Nov 14, 2017 4:26 am
I think you could probably go either way but it would be helpful to see how you've setup your current bike. If your current bike is setup where the handlebars are about in the lowest position they could be with a reasonable stem and you think you may want to get lower, I would drop down to a 49. If your happy with the fit you have on your current bike and have some room to adjust the handlebars down if needed , it sounds like the SL6 52cm could be setup the same as the 52cm you have today.
I run a 130mm -17 stem on my 52 cm tarmac. I had about 10000 miles on my 2014 49cm Tarmac and have about 2500 on my 52cm 2017 tarmac. Both worked just fine for me and are setup with about the same reach and drop. I think it's really up to you and if you want more handlebar drop.
PostPosted: Fri Nov 24, 2017 3:17 pm
i'm 174cm and ride 52. but my arm litter long ,so i think you are suit 49cm.
There are no new unread posts for this topic. 2018 S-Works Tarmac Disc
TonyM
33
7114
Wed Dec 13, 2017 4:38 pm
TonyM View the latest post
There are no new unread posts for this topic. Attachment(s) S-Works SL 2018
[ Go to page: 161 62 63 64 65 ]
ak47
965
163331
Thu Dec 07, 2017 5:38 am
ichobi View the latest post
There are no new unread posts for this topic. Help with 2018 Specialized S-Works Roubaix build
Vandit
Fri Nov 10, 2017 7:50 pm
Vandit View the latest post
There are no new unread posts for this topic. Tune Gum Gum in an S-Works Tarmac fork
morganb
Thu Nov 09, 2017 6:10 pm
4ibanez View the latest post
There are no new unread posts for this topic. S Works Tarmac or Scott Foil
sweetmate
28
3270
Sun Dec 03, 2017 7:41 pm
TurboKoo View the latest post
Users browsing this forum: Bing [Bot], Chris3g, dj97223, Google [Bot], ipaul, ms6073, PinaF8 and 46 guests
