Shoe Repair (BOA dial mount)
P90Puma
by P90Puma
I tweeted this out to fizik but they don't seem to monitor:
https://twitter.com/P90Puma/status/910594288899313664
@fizikofficial what do you recommend for repair glue? Epoxy, Shoegoo, something else? M5B didn't survive my 2nd #cross race.
Any suggestions guys?
motorapido
by motorapido
Not going to be easy to repair that,
The Boa has broken where it has been stitched into the shoe upper, the jagged break is where the plastic has been pierced by the needle when it has been sewn in to the upper construction, you can see the stitches in the shoe upper. dependent on the upper construction and if you can get a new BOA unit from Fizik then a good shoe repairer may be able to bond and stitch it back in.
Other than that, a strong impact adhesive and some strong dyneema or shoe waxed thread, sewn through what appear to be two large holes at the top of the boa clamp might hold as a temporary fix, but you might have to take the hit and replace them unless Fizik are willing to warranty it and replace.
commendatore
by commendatore
Call BOA directly, they should be able to do a warranty repair but you’ll have to mail the shoes into them.
P90Puma
by P90Puma
commendatore wrote:Call BOA directly, they should be able to do a warranty repair but you’ll have to mail the shoes into them.
Totally am doing this, thank you so much for the suggestion.
