Praxis Zayante Crankset - BB compatibility
Stolichnaya
by Stolichnaya
So, the new Praxis Zayante M30 crankset is intriguing. From the marketing description there is a step-down in the BB from 30mm to 28mm on the non-drive side, which implies that perhaps only a Praxis BB will be compatible. Can anyone advise if there are other M30 BBs that would work with the Zayante?
moyboy
by moyboy
yes it does step down. A lot of the Tarmacs had them and limited the owner to only Praxis cranks. Yet another standard.
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
Stolichnaya wrote:Can anyone advise if there are other M30 BBs that would work with the Zayante?
M30 is a Turn/Praxis only thing - nobody else produces or uses this 'standard'.
Turn is what the cranks were branded before Praxis decided to bring them under their own name. Same company, though.
moyboy wrote:A lot of the Tarmacs had them and limited the owner to only Praxis cranks. Yet another standard.
Nothing a change of BB won't sort - the frame isn't tied to running Praxis for the rest of its life.
Squint
by Squint
I've had chain suck and various shifting problems with mine so I'm going back to Shimano.
Attermann
by Attermann
No problems whatsoever with the chainset on shimano and a bb86 frame, I believe the bearings are made by enduro
