It is currently Wed Jan 24, 2018 7:05 am
Post new topic  Reply to topic  [ 3 posts ]
 Post subject: Campagnolo blue/red pads
PostPosted: Fri Aug 04, 2017 4:02 pm
I was wondering, what is the real difference between the two types of pads.
I know and I use blue pads with my shamals mille, and red ones with Boras, but the pads minus the colour basically look and feel the same. During last trip in the Dolomites, I saw this guy using red pads with Shamals mille and started wondering. Could someone tell more?
THx
PostPosted: Sat Aug 05, 2017 10:32 am
Shop Owner / Manufacturer
THx
Different composition, different hardness, different tendency to heat on braking, different heat retention ... apart from that, the same :-D
Seriously, though, yes, they are very different.
Red pads on the Milles in the wet are not good. Campagnolo tested for that. Originally it was thought that the Mille could be used with the red pads (in fact that was what it said in the launch info) but problems in the wet came to light and so the blue pad was developed.
Blue pads on carbon will cook the rim surface even braking the way that you should brake on carbon (hard and for very short periods). They generate and retain too much heat.
FWIW if you mix these pads up and you are in warranty on your wheel set, you won't be any longer ...
PostPosted: Sat Aug 05, 2017 2:42 pm
There's only one reason why you would use red pads on Shamals - when you've swapped your wheelsets but forgot to swap pads too.
Good luck back on your carbon rims with those pads full of aluminium dust, too.
There are no new unread posts for this topic. Canyon Gran Tourismo blue
Edu24h
Fri Jan 05, 2018 2:36 pm
Edu24h View the latest post
There are no new unread posts for this topic. Can I add a new 9150 Di2 Battery with blue tooth to my 9070
mnmasotto
Sat Mar 11, 2017 9:23 am
TurboKoo View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1568
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Zipp 303/404, anyone using koolstop pads?
TurboTommy
26
2358
Wed Jul 12, 2017 2:21 pm
dorin View the latest post
There are no new unread posts for this topic. Cycling short pads - your thoughts?
milesthedog
16
1894
Thu Apr 20, 2017 1:26 pm
milesthedog View the latest post
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 19 guests
