It is currently Thu Jan 18, 2018 7:17 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
PostPosted: Fri Jul 28, 2017 11:23 am
Hi. I have just purchased the Campagnolo Record EPS V3 upgrade kit, and wil start installing it soon. My frame is prepared for both electronic and mechanical drivetrains, and I am currently running Record mechanical.
This will be my first installation of electronic drivetrains.
Does anyone have tips, tricks, pitfalls etc which can do my job easier and make the solution look neater (especially in the cockpit area)?
Tor-Inge
PostPosted: Fri Jul 28, 2017 11:41 am
Tor-Inge
My tip would be to take it to a shop with experienced mechanics...
:smartass: :smartass: :smartass:
PostPosted: Fri Jul 28, 2017 12:23 pm
Good tip, but I prefer to do it myself. For over 10 years i have built and maintained my own bikes with mechanical Campagnolo. I have never had the need to take it to a shop/mechanic. So i really want to do it myself to learn to maintain it after it is installed :-)
PostPosted: Fri Jul 28, 2017 12:53 pm
Do you have the cable guide magnets? These make routing the wires a breeze, especially through the chainstay.
The only other thing I can think of is to remember to fit the cable protection BB adapter sleeve before installing the cups. I know someone who forgot this (and no, it wasn't me!)
PostPosted: Fri Jul 28, 2017 12:59 pm
Thanks Mockenrue. Maybe i should buy the guide magnets. I have normally just used some thread and a vaacum cleaner to get the thread through the frame. And then just pulled the wire back using the thread. not sure if this would work on a EPS wire though.
PostPosted: Fri Jul 28, 2017 1:10 pm
Made mine using old gear cable and small magnets held on with tape...... worked on 2 bikes so far
PostPosted: Fri Jul 28, 2017 2:10 pm
yep...should work just fine...the kit is over kill imo
PostPosted: Fri Jul 28, 2017 2:33 pm
no tricks at all just a straight install,just like everyone, I made my own cable guide with brake cable and magnet glued and shrink wrapped it. on the V3 I mounted the battery on the seatpost with the 32mm adapter. good luck and have fun .
2017 De Rosa King Xs
2017 Colnago C60
2017 Colnago Concept
PostPosted: Fri Jul 28, 2017 4:26 pm
i used the park tool internal cable magnet set.
you will probably end up pulling and refeeding the cables to make it perfect , so the choice is yours.
I suggest getting some shrink wrap tubing so that you can bundle up the eps wires at the cockpit with the brake cables.
PostPosted: Fri Jul 28, 2017 4:41 pm
I've done several EPS installs, two of my own and a couple for friends. After the first, super straight forward. The first time I did it, I watched the Campy videos on their website and found them very helpful. I try to be a measure twice (or three times) cut once type...
PostPosted: Fri Jul 28, 2017 6:09 pm
Installing EPS in any frame made for electronic shifting is actually quite easy... the only challenge you might run in to (although with the C60, I doubt it...) is the hole diameter for the EPS is larger than for Di2 so it might be a tight fit. Second challenge (with v2 EPS) is where to place the charge port (again, being a bit creative, I'm certain you can find a spot... on my road bike (Pinarello F8) it's a breeze as you can just use the threaded port on the front in, on my tri bike (BMC TM01), I left it inside the frame as you have an access into the seat tube behind the back wheel, on my wife's tri bike (Ventum One), I got an extension cable and left the charge port right behind the stem, and on her road bike (Parlee Z5 SLi), I opened up the drain hole slight and fit it in that).
PostPosted: Fri Jul 28, 2017 6:29 pm
I've done a few also (including 2 C60s).
1. The location of the interface is up to you. I put mine on the brake cable.
2. Many people need to enlarge the hole for the interface plug. A file or a dremel tool will do. The problem is just a little excess paint.
3. The noise from the wire in the downtube drove my crazy. So, I put some foam tubing around it. You need to take the fork out to do this. http://www.ebay.com/itm/DMI-Tube-Foam-S ... SwWnFV8bzJ
4. Zero setting the rear is easier with the chain off. You can line the jockey wheel with the cog.
5. Getting the front derailleur perfect is the hard part. My method is to mount the derailleur without the chain. Set the height. Use Zero-Setting and move the outer cage above the outside chainring. Hold a popsicle stick against the chainring, and rotate to crank to pass it back and forth past the derailleur cage. Set the outer cage so that it is parallel to the chainring. Mount the chain, and zero-set the front again. This works better than the Campy tool.
PostPosted: Fri Jul 28, 2017 7:54 pm
Read the Campag EPS user guides and watch the vids as referenced above. EPS is then straightforward.
PostPosted: Sat Jul 29, 2017 7:49 am
Somebody give joeyb1000 a high five
My Strava Profile
2016 Cannondale CAAD12
PostPosted: Sat Jul 29, 2017 8:35 am
Wow. Really great feedback in the posts above. Thanks a lot! ☺
I will start installing tomorrow evening. I expect to run into a few issues, but I think your tips will save me time and bother.
There are no new unread posts for this topic. Campagnolo SR ITA BB cups installation method
karhu
14
852
Mon Jul 03, 2017 11:15 pm
AJS914 View the latest post
There are no new unread posts for this topic. ILink and Campagnolo SR on a Colnago C-60 help
dgasmd
Wed Dec 06, 2017 11:09 am
dgasmd View the latest post
There are no new unread posts for this topic. Colnago c60 + campagnolo problem
Fri Dec 22, 2017 4:31 pm
wilwil View the latest post
There are no new unread posts for this topic. Bike frame defect Colnago
itguy
20
3794
Mon Mar 20, 2017 10:39 pm
whodesigns View the latest post
There are no new unread posts for this topic. Colnago World Cup frame size [help]
biker11122
16
1106
Sat Aug 05, 2017 7:17 pm
biker11122 View the latest post
Users browsing this forum: benjaminm3, eliflap-scalpel, genesis692 and 17 guests
