Cannondale Supersix EVO – fast track weight reduction project
garjo
by garjo
I've just calculated quickly all those weights you wrote plus stock weights of frameset, groupset and wheelset and yes, the weight is correct.. the complete Red22 helps a lot.
Imo maybe this build appears to be heavier because the paint skeme with a lot of white and the big decals on the wheels, aesthetics so different from the usual WW stealth bikes
Asteroid
by Asteroid
garjo wrote:I've just calculated quickly all those weights you wrote plus stock weights of frameset, groupset and wheelset and yes, the weight is correct.. the complete Red22 helps a lot.
I just looked at your stellar build. Your Hi-Mod and AX wheelset slaughters my totals!
My weights will creep up with the Dura Ace swaparoo and more durable Veloflex Criterium tires.
Might try to use some other similar components used by other WWers to cancel it out. :thumbup:
Oldbie
