It is currently Wed Jan 17, 2018 8:32 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Mon Jul 10, 2017 12:07 pm
So, what would we consider practical safe places to shave weight from a built bike ?
Alloy bars and stem to carbon.
Bottle cage bolts - leading to -
Bottle cages naturally.
Stem and bar bolts ?
Skewers ?
Tubes.
Tyres.
Wheels ? (running 303 firecrest clinchers)
Pedals.
What else could be dropped withstanding a higher spec group set. Running Ultegra 11 speed with Rotor P2Max so no really weight saving the chainset, but is Dura Ace 'that much lighter' ? I still use 7900 calipers as I 'think' they are lighter than 9000 and 9100.
I have threaded ITA BB and looking at a C-Bear ceramic option but cannot find a weight and wonder if any saving weight wise, though performance of C-bear is superb.
Any pointers ideal. I have surfed here for years and never really had the desire to lighten the load as most bikes 14-17lb all in but interested to see how.
D.
PostPosted: Mon Jul 10, 2017 12:37 pm
You are better of with an alloy stem. most "carbon" stems are alloy stems wrapped in carbon. carbon isn't a great material for stems because of all the different forces.
you could use Alloy bolts on your bottlecages ,but use titanium on your stem.
don't go the ceramic way for the weight. super high price for very little saving.
look at your seatpost, most bikes come with really heavy ones
PostPosted: Mon Jul 10, 2017 1:13 pm
Most? Some are, like FSA OS99 or Ritchey matrix, but it's pretty easy to tell. Most carbon stems from reputable high end brands are full carbon. Zipp, Enve, 3T, even the bike manufacturers house brands like Giant's SLR.
That said in terms of weight saving you'll get practically nothing over a high quality alloy stem unless you go all in with something boutique, German and expensive. :wink:
PostPosted: Mon Jul 10, 2017 2:17 pm
that's what i meant... i know some people that paid €80 for a carbon most stem and in the end it was just an alloy one wrapped with some "wannabe"carbon
PostPosted: Mon Jul 10, 2017 3:21 pm
Re carbon stems: It's been sometimes said that they should dampen vibrations a little - similarly to carbon bars etc. However I haven't found any credible information regarding this. And since the carbon layup has to be much more complicated here, it may be possible that this dampening effect it effectively none. Has anyone compared some carbon stems to the alloy ones in this regard?
PostPosted: Mon Jul 10, 2017 6:49 pm
Nowadays with +25c tires, I say most of the "comfort" can be had from bigger tires. I think carbon stems are not particularly "light", but they can be made to be very stiff (for the weight).
PostPosted: Mon Jul 10, 2017 7:24 pm
Yes, I feel it very distinctively, carbon dampens road feel much, much better than alu...
PostPosted: Mon Jul 10, 2017 7:57 pm
Agreed, but every little thing counts (marginal gains)... ;-)
And what particular stem do You have?
As for weight savings:
- tubes & tyres (or go tubular but that may be quite expensive transition)
- bars, saddle, skewers, bottle cages (there are some decent ones at Aliexpress or you may even try these viewtopic.php?f=3&t=132403 ) may be one of some interest
- then even more expensive stuff such cassette (SRAM Red XG-1190 is slightly lighter than its Shimano counterpart), hubs (if you replace ZIPPP 77/177 with for example Carbon-Ti you may save about 140g), brakes (EE)
- I wouldn't bother with crankset or rims in your case (you may go that way of course, but that would be costly)
Basically check what you can find and how much does it cost and weigh, compare it with what do you currently have and decide what's worth it (basically $ per g saved)
PostPosted: Mon Jul 10, 2017 8:15 pm
I saved 500 grams from bars, post, saddle, and skewers alone - albeit at nearly $700.
Depending on your existing cassette, cranks/chainrings, and chain, you can find a good deal of weight-savings there, as well. This makes sense if your present components need replacement due to wear. You can realize another 300 grams here.
My favorite upgrade was buying a set of Campagnolo Bora Ultra 35 tubulars. Light and sweet and costly!
Oldbie
PostPosted: Mon Jul 10, 2017 8:17 pm
regards subject title... belly, ass, moobs
PostPosted: Tue Jul 11, 2017 3:13 am
:up: :thumbup:
Better than free too, less food costs less money!
Road: Orbea Orca, Guru Praemio, Ricthey Break-Away, Colnago Master X Light, Gios Compact Evo, Pinarello Gavia, Bottechia SLX, Bianchi Vittoria, Legnano Gran Premio
Cross: Ritchey Swiss Cross
MTB: Scott Scale, Norco Bigfoot
PostPosted: Tue Jul 11, 2017 5:40 am
There are dirt cheap eBay carbon seatposts weighing 175g for under 30usd.
Kalloy Uno stems weighing under 120g for about the same.
I've had good luck with them both.
There might be replacement titanium axles for your pedals. I swapped out the chromoly axles on my Speedplay Zero pedals saving 50g.
Sent from my A0001 using Tapatalk
PostPosted: Tue Jul 11, 2017 11:10 am
The Ceramic C-bear BB I was looking at was 66g, (41-30).Their website normally says a weight at the bottom of the page to each pacific BB.
PostPosted: Tue Jul 11, 2017 4:46 pm
Some of this depends on what you already have.
Your Firecrest clinchers are not terribly light wheels. You could probably shave a full pound off the bike with some lower profile carbon rim tubulars. You could even shave a half pound just by going to some aluminum clinchers or even Reynolds Attack wheels.
As for your bar, stem and post, you could certainly look there to save weight. In many cases, an aluminum stem will be lighter than a carbon one. Some aluminum bars are pretty light - low 200s, but going to a nicer carbon could get you under 200. But it all depends one what you are starting with. If your current bar is 350 grams, going to a nicer aluminum can still save you over 100g. But if you're sitting at the low 200s, you're not going to see a bid weight drop going to carbon. And if you go aero carbon, you may go up in weight.
PostPosted: Thu Jul 13, 2017 11:02 pm
I have run the following stems: Giant SLR, Bontrager XXX, 3T Arx whichever is the carbon one...
Especially with the Giant, I can compare Contact SL and Contact SLR, and the SLR smoothes the road much much better....
There are no new unread posts for this topic. Alright, how to reduce weight for Tarmac Sworks sl6 disc
unlucky
12
1086
Fri Dec 15, 2017 10:01 am
L3X View the latest post
There are no new unread posts for this topic. FMB Competition CX Weight
ab01ns
Fri Feb 10, 2017 7:07 pm
ab01ns View the latest post
There are no new unread posts for this topic. bike weight
huffington
Sat Apr 29, 2017 12:54 pm
shineplus View the latest post
There are no new unread posts for this topic. Most light weight powermeter?
Chans1ee
Tue Jan 09, 2018 5:13 am
Chris3g View the latest post
There are no new unread posts for this topic. Attachment(s) 2018 Cervelo R5 weight
salesguy
Mon Oct 09, 2017 1:54 pm
salesguy View the latest post
Users browsing this forum: Bing [Bot], gaspard123, Google Adsense [Bot], jpshorts, nobuseri, Stueys, vladi78 and 39 guests
cron
