It is currently Thu Nov 23, 2017 10:44 am
PostPosted: Fri Jun 30, 2017 3:37 pm
Hi, I recently finished wiring up my bike using the new EW-RS910 handlebar junction box from Shimano.
What I can't really wrap (pun intended) my head around is how to wrap the handlebar on the side with the junction box.
I planned on starting the wrap on top to get a clean finish, but that depends on being able to use a barend plug to finish the tape on the bottom. Should I try and use the same 'trick' to start at the bottom without squishing the bartape into the barend?
See photo for how I've plugged in the junction box (the same way as shown in a video from shimano). My handlebars are S-Works aerofly bars.
PostPosted: Fri Jun 30, 2017 3:50 pm
While I won't argue the merits of wrapping inside out or outside in I will say with my junction ... I started on the bottom, gave it one full wrap and continued on. I used 3T tape which has a bit of stick strip on the base and I had zero issues with look\feel. Having said that it does kill me a little inside to not be able to start with a bit of tape inside the bar like I traditionally do and do a "proper" wrap. But it turned out better than expected. I did not tape the junction on however beyond the double sided tape I used beneath to try and keep it from being lumpy.
Just ride ..
I started wrapping with diagonal in beginning, just like I finish also. In my opinion it looks really good like that. I'm not fan of wrapping from top as it makes life span of handlebar tape really short.
PostPosted: Fri Jun 30, 2017 5:17 pm
I cut the end at an angle and started at the bottom and have a couple thousand miles on it with no issues, and did a friend's bike the same way. But yeah, you will have to use electrical tape at the top. Probably no way around that other that some super specific and very thin two-sided tape and some clever wrapping technique. Not even faintly worth it.
PostPosted: Fri Jun 30, 2017 10:45 pm
On page 57 in the dealer manual from Shimano, they state "Cut the end of the handlebar tape diagonally and wrap it over the handlebar holders..." They have some diagrams there showing this.
PostPosted: Sat Jul 01, 2017 10:35 am
I did it exactly like this:
https://youtu.be/5MzIiv7pewE?t=11m7s
To make a clean cut, first wrap the tape one circumference around the bar (square, without sticking it), and mark the point where the tape meets at the end of the bar. Then cut as straight as possible from that point towards the opposing corner of the tape. Additionally, you can cut off the part of the tip which has no glue underneath, because it won't be exposed anyway, so less bulk and no loose end. Looks perfect on my RS910.
PostPosted: Mon Jul 03, 2017 11:17 pm
I used 3M two sided tape at the bottom for the first 4 cm, then started my normal wrap. Similar idea to the reverse electrical (vinyl) tape method shown in the Park video. Without stuffing the tape in the bar end, I had small faith the adhesive on the Fizik tape I used would actually hold well for any length of time.
I bought 3T Aeronova bars so I could wire everything internally. Worked a charm.
lance - no, not that guy, I started racing in 1976.
1980 A-D Ultima
1999 Softride TT
2013 Cervelo S5 Team LE
PostPosted: Tue Jul 04, 2017 11:21 pm
Thanks guys, ended up taping from the bottom as shown in the manual and in the linked vid. Looks really good, will see how it holds up!
PostPosted: Wed Jul 05, 2017 12:39 am
i angle cut the tape and use double sided tape at the bar end
Skunkworks Bikes
PostPosted: Wed Aug 02, 2017 4:28 pm
I've always done this even without a junction box.
There are no new unread posts for this topic. Does anybody know of a round carbon Handlebar that works with internal Junction A, EW-RS910?
Voyagertwelve
16
1263
Wed Nov 22, 2017 11:56 pm
Voyagertwelve View the latest post
There are no new unread posts for this topic. Shimano EW-RS910 junction box
morganb
7
887
Sun Nov 12, 2017 4:24 am
egebhardt View the latest post
There are no new unread posts for this topic. RS910 junction in the steered tube,
dtwolfen
Tue Jul 25, 2017 9:14 pm
dtwolfen View the latest post
There are no new unread posts for this topic. why is the Di2 EW-RS910 bar end junction box not more widely adopted by pros?
ph
Wed Jul 05, 2017 6:33 pm
ipenguinking View the latest post
There are no new unread posts for this topic. Shimano ST-R785 Compatibility EW-RS910 Junction Box
gazzaputt
Tue Sep 12, 2017 9:17 pm
gazzaputt View the latest post
Users browsing this forum: Bing [Bot], cyclenutnz, Google [Bot], Google Adsense [Bot], karmaz, Mockenrue, TheBlackPath, tomycs and 23 guests
