It is currently Tue Jan 16, 2018 10:54 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Focus mares fork mod
PostPosted: Fri Jun 09, 2017 7:32 pm
So got a focus fork with a 15mm thru axle and this past winter got to thinking about not carrying my multitool with me but how. Well picked up an industry9 matchstix at a race with a rock shox thread and got to thinking I can use this. So order a 15x1.5 bolt off Amazon and get to work with a hand file.
First create notch in bolt for set screw to recess intoImage
Then make channel so set screw will thread into bolt. Next round corners of bolt a they were just a little to large. Image
Then make sure it fitsImage
It adds weight but I can shave probably another 6 grams when I get the die to make the threads longer on the axle. Right now adds 60 grams for 5 wrenches a chain link a chain beaker and spoke wrench. Peace of mind is much greater though. Image
I can then cut axle down and take a bit out.
 Post subject: Re: Focus mares fork mod
PostPosted: Mon Aug 07, 2017 8:13 pm
Why didn't you buy a RAT axle and end cap from focus?
PostPosted: Thu Aug 10, 2017 12:39 am
Because I wanted the tools from the matchstix.
Sent from my LG-H700 using Tapatalk
PostPosted: Fri Aug 11, 2017 1:28 pm
Oh I see now, I didn't know that there is a multitool hidden inside.
I'd like to replace RAT with threaded thruaxle in my izalco but it's not that easy as I initialy thought. Length of the axle is not standard so I can't use any axle from the market. Endcaps should be cutom milled and anodised. At the end I'm not sure that 1 small bolt holding endcap would handle twisting loads.
PostPosted: Sat Aug 19, 2017 9:55 pm
I'll let you know if I have a failure. You are right about getting threads anodized if new ones are cut. I just used a spacer on the non disc side. Ideally I'd have a custom piece of aluminium cut and threaded for the axle but not enough time to go after that.
There are no new unread posts for this topic. Focus Mares CX Tire clearance
Dennistwowheels
7
1159
Thu Oct 12, 2017 10:26 am
Dennistwowheels View the latest post
There are no new unread posts for this topic. Felt F4x vs Focus Mares Rival 1 vs Spesh Crux Elite X1
otoman
Wed Apr 26, 2017 6:01 pm
AJS914 View the latest post
There are no new unread posts for this topic. Focus on...Focus
in Catch all // Gallery threads
Squashednuts
Mon Nov 06, 2017 9:38 pm
tvillumsen View the latest post
There are no new unread posts for this topic. Any Focus R.A.T. users? I need some help
nemeseri
Sun Aug 06, 2017 7:21 pm
nemeseri View the latest post
There are no new unread posts for this topic. Focus Izalco Max
muffinman
38
5834
Sun Oct 22, 2017 9:37 pm
themidge View the latest post
Users browsing this forum: No registered users and 4 guests
cron
