It is currently Thu Jan 18, 2018 12:50 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Wed May 24, 2017 5:20 pm
Thanks for all the responses guys
My original question was more about cheaper options vs swissstop but the performance comparisons amongst swisstop pads are equally interesting
PostPosted: Wed May 24, 2017 8:02 pm
Have you got a link to the ones you were thinking of?
Using Tapatalk
PostPosted: Thu May 25, 2017 5:40 pm
Specifically I was looking at the 'koolstop' range but am open to suggestions from anyone who can compare swisstop/Zipp pads with other offerings. I'm a little weary of using a pad that isn't well recommended as I don't want to damage the brake track and obv want good performance. I'm happy enough with the 'black prince' pads but will also try the others that have been recommended to see if they're even better.
I was just wondering if anyone had any feedback on the koolstop pads as they're so much cheaper. So if they offer similar performance then all good. :)
PostPosted: Thu May 25, 2017 10:32 pm
No experience of the Koolstop range, but can recommend the Wiggle Lifeline carbon pads. Brilliant and such good value for money.
http://www.wiggle.co.uk/lifeline-perfor ... pack-of-4/
PostPosted: Fri May 26, 2017 2:53 am
I was worried they were a bit to hard/harsh on the rim when I tried them. Might be paranoid?
Using Tapatalk
PostPosted: Fri May 26, 2017 10:22 am
Afaik the Wiggle blue pads are re-badged original Reynolds?
I've just bought 2 sets to try on my 303 tubs as my Black Prince's are low.
PostPosted: Fri May 26, 2017 10:57 am
They turn brown if they get warm. I was thinking they were Cryo's.
Using Tapatalk
PostPosted: Fri May 26, 2017 10:11 pm
I suspect the maybe old Reynolds cryo design. The newer design has a larger surface area. The material appear to the the same. I've not experienced the brown (burning?) of the pads, but the grooves quickly fill up with grayed pad material. Wear rate is high, however they are cheap and they appear to be sacrificial to the rims, I am prepared to accept that I will have to replace regularly.
I should add that I am using them on 2015 Reynolds Assaults and 2017 Light bike 28mm carbon rims.
PostPosted: Fri May 26, 2017 11:41 pm
This was on Zipps. May have just been old pad material off the rim.
Using Tapatalk
PostPosted: Wed Jul 12, 2017 2:02 pm
Hi Nefarious, are you saying the Zipp Tangente Evo Pro are better than BP? How to they perform in wet conditions, did you have a chance to try? I used BPs and was very happy till it rained and must have turned a serious amount of hair into grey one...
Nefarious86 wrote:
The power difference between BP and Zipp pads are night and day. And for $45Aud for 4 from Sigma I'll happly pay the difference.
PostPosted: Wed Jul 12, 2017 2:04 pm
I find them to be better all round
Using Tapatalk
PostPosted: Wed Jul 12, 2017 2:21 pm
Thanks, I'll give them a try
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Zipp SL-88 vs. Zipp SLC2 TB
TSJ
Thu Sep 21, 2017 8:55 pm
TSJ View the latest post
There are no new unread posts for this topic. Campagnolo blue/red pads
Willier
Sat Aug 05, 2017 2:42 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Brake pads for Lightweight Meilenstein
mike001100
21
1351
Fri Nov 10, 2017 12:01 am
glepore View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1098
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
Users browsing this forum: coriordan, gmarsden, pyrahna, TuplaO, Vermu, Vtrdaz, Yahoo [Bot], Zakalwe and 41 guests
