It is currently Tue Jan 23, 2018 7:38 am
PostPosted: Wed May 10, 2017 4:02 pm
I've had some issues with my chain occasionally jamming when I shift down on my Record EPS group. I've also had the chain occasionally shift over the big ring when shifting up. It does not happen too often. Maybe once every couple months. I bought the front derailleur alignment tool thinking that may be the issue. Can you tell if my front derailleur is aligned properly with the tool? It looks like rear of the front cage needs to be rotated out more.
PostPosted: Wed May 10, 2017 4:20 pm
Yes, that's not even close to parallel with the chainring. I don't use the tool. I use an 8mm allen wrench with the flat side against the teeth of the large sprocket and (for mechanical) I use the low limit screw to hold the front derailleur out to the big ring so that when I turn the the crank the flat side just grazes the edge of the front derailleur evenly through the rotation. This ensures it's parallel and it's tactile, so you can hear and feel the grazing. You can do it by sight using the tool above with the line on it as well. And from your second pic, you've got a ways to go. This is the very first step to ensuring your shifting will be spot on.
Colnago C60 - PR99; Trek Koppenberg - Where Emonda and Domane Meet;
C59 Five Years Later
Trek Emonda SL Campagnolo SR; Special Colnago EPQ
PostPosted: Wed May 10, 2017 4:55 pm
Thanks Calnago! So all I need to do is rotate the front derailleur more to make it parallel with the line?
PostPosted: Wed May 10, 2017 5:14 pm
Well, that's the first step. But it's one of the most important and a very critical one. In addition, I like to set the gap between the big rings tallest teeth (when the crank arm is in the 3 o'clock position) and the derailleur cage to between 2.5mm and 3mm. Meaning when the edge of the derailleur cage is directly over the teeth, I can pass a 2.5mm allen key between the teeth and the cage, but not a 3mm key. This has provided me good results and has been ok for swapping between any cassettes from 11/23 through to 11/29. Sometimes, if you have the cage set really close to the teeth, and then throw on a larger cassette, the chain could touch the top of the cage under certain conditions when on the largest cog. Although I don't think that happens as much, or at all, with the new stuff. I've just settled on that distance as being good for providing great shifting in all conditions regardless of the cassette I'm using.
PostPosted: Wed May 10, 2017 5:25 pm
I checked the gap using a 2.5 Allen key and my derailleur is way higher than that above the front ring. Sounds like I need to bring it down and rotate it out. Thanks again Calnago for your help!
PostPosted: Wed May 10, 2017 5:30 pm
Yes, those two changes should make quite a difference I would think.
PostPosted: Wed May 10, 2017 8:57 pm
Hey there,
I also found the following video quite useful. At around minute 4 they show how to use the tool.
https://youtu.be/Y_1pkG2XfT0
PostPosted: Wed May 10, 2017 11:57 pm
And for those that don't know, on the official Campa site there are vids like this grouped under: Support > video tuts
https://www.campagnolo.com/WW/en/Support/support
There are no new unread posts for this topic. Attachment(s) Colnago C60 Bottom Bracket Tool
thebman
35
2937
Mon Jul 17, 2017 2:54 pm
thebman View the latest post
There are no new unread posts for this topic. Di2 battery drainage / diagnostics tool
wheelsONfire
7
1285
Fri Apr 14, 2017 2:26 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Online Frame Comparison Tool??
EvilEuro
16
1079
Thu Jul 20, 2017 11:58 pm
silvalis View the latest post
There are no new unread posts for this topic. Alternative Tool For Removing Battery Cover
ipenguinking
7
474
Sat Oct 14, 2017 3:20 pm
ipenguinking View the latest post
There are no new unread posts for this topic. Shimano Lockring Removal Tool For Zipp 177 Hub
MrMojo
Sat Jun 10, 2017 11:08 pm
MrMojo View the latest post
Users browsing this forum: alcatraz, Guevarca and 48 guests
