SRAM or Shimano 11 speed cassette
beanbiken
by beanbiken
pdlpsher1 wrote:
beanbiken wrote:My DA cassettes are 9000 series.........
Maybe a redundant question but I assume your 9000 cassette works perfectly with 9150? So in a nutshell both Red and 9000 cassettes work perfectly with 9070 (it did for me) but only 9000 works with 9150.....
Yep, that seems to be my situation. :oops: Would love someone to tell me I am doing something basic/noob wrong but I can't for the life of me work it out. A 9000 12/28 works a treat with RD9150 but the 11/28 red is not happy and yet it works a treat with the RD9070. I'm running the 9150 with the Sram red 11/28 at the moment. It's usable but far from ideal........... and I don't really want to chew up my Extralite hubs with the DA cassettes so I will keep persevering for now............ but I can see flea bay getting another couple of listings :(
SM
Ahhh, coffee & carbon
sungod
by sungod
are you using a sram chain? if not, might be worth trying to see if the shifting improves
Imaking20
by Imaking20
I started with the SRAM chain due to the 1190 cassette. Swapped to Dura Ace chain when I caved and installed the 9100 cassette. Shifting is maybe a little better with DA chain and 1190 cassette but still not ideal.
Current:
T2
Retired:
muntos
by muntos
I'm also looking to change my Miche 11-30 cassette with the new Dura Ace CS-R9100 (11-30) or SRAM XG-1190 (11-30). Between these 2 which one would you recommend for a combination of Ultegra DI2 rear derailleur with 36-52 Rotor Q rings (for best shifting and silence, weight is similar from what I know...)?
pdlpsher1
by pdlpsher1
killer6144 wrote:
Sat Dec 30, 2017 6:19 am
sram 11-28 don't has 16T
That's incorrect. Sram has it. Shimano's 11-28 doesn't. The list below is from Sram's website.
GEAR RATIOS 11-25: 11,12,13,14,15,16,17,19,21,23,25, 11-26: 11,12,13,14,15,16,17,19,21,23,26, 11-28: 11,12,13,14,15,16,17,19,22,25,28, 11-30: 11,12,13,14,15,17,19,21,24,27, 30, 11-32: 11,12,13,14,15,17,19,22,25,28,32
KCookie
by KCookie
I change between two sets of wheels frequently one with SRAM cassette and one DA. RD & FD are 9150. Both 11-28. I seem to be having problems with the SRAM 11-28 cassette, won't drop in to the 11 and the middle gears seem to be slow down shifting, but no problem at all with gear changes on the DA. Second time this has now happened.
Would it be better to have two cassettes the same?, if so I'll buy another SRAM.
Cheers
Delorre
by Delorre
KCookie wrote:
Sat Dec 30, 2017 11:07 am
Cheers
I guess it has nothing to do with the cassette, but simly a slight difference in hub spacing. Hence why you can't drop in the 11. Use some thin shims as to space both wheels identically and you are good to go. Had to do the same with my Elite Drivo trainer. A 2mm spacer was enough to have the same crisp shifting as with a regular rear wheel.
KCookie
by KCookie
Would that still be the case if both wheels are the same brand. Lightweight Ventoux and Obies.
Cheers
glepore
by glepore
Yes, it could. I'd set it up so that your limit screw allows it to drop into the 11 on the "hesitant" wheel. If that then screws up shifting on the other wheelset, a thin .25mm shim or two (these are available from wheels mfg.) behind the cassette on that wheel until you're good w/ both.
Sometimes its just the way tolerances stack.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
KCookie
by KCookie
Awesome, thanks for the advice.
tabl10s
by tabl10s
Rotor Uno!
2016 Orbea Orca OMR:
15.2lbs(6.89kg)
2013 Wilier Zero.7:
13.65lbs(6.19kg)
2016 Rca(build in-process)
pdlpsher1
by pdlpsher1
Cheers
On your 9150 RD, try backing out the high gear limit screw. The 9150 RD moves to a point lower than the 11th position, then back to the 11th position after one second. This will help your shifting to the 11th.
fh8425
by fh8425
Kurets wrote:
Sat Apr 29, 2017 7:18 am
Do you ride solo or in a group? With a 52 in front the SRAM 11-28 has a gap in gearing around 30km/h because of the steep ramp in the final four gears. So for anything other than group riding/racing where speed on the flats is typically higher than 30 and you'll only use the steep part of the cassette for climbing, I'd recommend a different cassette.
Depending on your budget a Dura Ace 12-28 might fit? Or an 11-25/12-25. I live in a very flat area, so a 12-25 is perfect with close ratios all the way through the cassette: 12-13-14-15-16-17-18-19-21-23-25
+1
