Tornova alternative
havana
by havana
I own a 3T Tornova Team (carbon) handlebar but I'm struggling to create a nice and even transition between the shifters and the top of the bars.
Any alternatives?
Need to haves
- traditional bend
- flat transition shifters>top
- fat or oval top (not wing)
- material not really important
Pro Vibe S Round seems to tick all the boxes. Hard to come by but found one on eBay. Any other alternatives? Zipp 88 has a thin top, not sure about the Shitchey Neoclassic?
Most "innovations" in cycling are solutions for non-existing problems.
Slack
by Slack
Ritchey Neo Classic has a traditional drop with a flat transition, available in carbon and alloy.
http://s1280.photobucket.com/user/kaise ... .jpeg.html
havana
by havana
True, but it has a "thin" top.
Fizik Cyrano snake?
Slack
by Slack
It's just regular handle bar width on the top, it's not thinner.
boots2000
by boots2000
Here is something to consider.
Traditional bend bars are not really designed to have a totally flat ramp to the shifters.
To get a flat ramp, one has to angle the bars more than what is ideal.
A few older shifters do a better job, but most modern 11 speed shifters do not-
If flat ramp is your primary consideration, look at a bar like an Enve compact, Deda Zero 100, etc..
AJS914
by AJS914
havana wrote:True, but it has a "thin" top.
You can always double wrap the bars if you want it fatter.
wingguy
by wingguy
havana wrote:Need to haves
- traditional bend
As a point of order, these requirement are mutually contradictory. A traditional bend bar has a slope down to the shifters. It is part of what a traditional bend bar is. What you're asking for is a deep drop bar.
That said, the 3T Aerotundo has the same drop and similar bend to the Tornova but with a flat transition to the shifters. That does mean the bar is longer in reach though, and for some reason it doesn't flare like other 3T bars so a 42 does measure 42 at the hoods, etc.
MisterMuncher
by MisterMuncher
Fizik Cyrano snake?
Not thin in any way. Good bars, but chunky. Very noticeable difference between them and the KCNC bars I also use.
