It is currently Fri Jan 19, 2018 3:04 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sat Mar 18, 2017 6:43 pm
Hi. Maybe someone here have any experience with replacing power cell in PU14-REEPS for new one?
My battery taking no charge after being discharged for some time. I have disassembled it and found that all 3 Panasonic NCR14400 batteries are completly dead. And I need to replace them. But have been unable to find same batteries for selling anywhere.
Maybe someone can suggest any other batteries to replace my?
P.S. Is there is a chance to use NCR18650 batteries here with standart electronics?
PostPosted: Sun Mar 19, 2017 12:33 am
As long as you keep the same voltage it should not matter. I doubt the 18650 fit inside the stock casing as they are bigger. 18.5mm x 63.5mm. The NCR 14400 are 14.4mm x 40mm. They are also lighter compared to 18650. 16gr. vs 46gr. The 18650 does have much bigger capacity. . Your battery will last much longer, but will be much heavier. You will have to use them without the stock casing.
http://www.batteryspace.com/aaaaaseriesli-ioncells.aspx
You could use the 14430 instead 17gr. Or maybe the 14500 28gr.
PostPosted: Sun Mar 19, 2017 11:31 am
The main problem that campagnolo stock case is very tight. Most of the space is taken by PCB. And there is not enough space inside it event to put 14430 batteries, because 3 of them will be 9mm larger in overall the stock 14400. The only way to put inside stock case, is to remove protection board from battery pack.
Maybe someone can suggest the way, to make new casing?
As far as I'm understand from this Campa doc (https://www.campagnolo.com/media/files/ ... _09_15.pdf), system operates using 10.8 voltage, so I need to install 3x 3,7 volts battery (14400, 14500 or 18650) in any case?
PostPosted: Sun Mar 19, 2017 5:11 pm
You don't really need to use the stock casing really. The battery goes inside the frame so it is protected from the elements. You could use some battery shrink wrap to hold the cells in cylindrical shape just like the stock battery. It will be lighter than the stock casing. To prevent damage, use some foam around the battery when you install it so that it doesn't move.
Yes three cells at 3.6-3.7v will match the stock voltage.
There are no new unread posts for this topic. Campagnolo EPS V2/3 Battery charger problem.
SolongSid
16
1868
Thu Dec 21, 2017 11:24 pm
Disc0 View the latest post
There are no new unread posts for this topic. SRAM Red RD repair
thePrince
Sun Aug 27, 2017 4:07 pm
sungod View the latest post
There are no new unread posts for this topic. Campy EPS Charger Repair
wjshook
Mon Nov 27, 2017 11:28 pm
There are no new unread posts for this topic. Mysterious Di2 battery drain
havana
26
2299
Fri May 26, 2017 6:45 am
eaglejackson View the latest post
There are no new unread posts for this topic. Di2 BT-DN110 Battery Discharge
gazzaputt
Sat Nov 04, 2017 7:43 pm
kode54 View the latest post
Users browsing this forum: Bing [Bot], Chris3g, SimmyD, sun, tonytourist and 33 guests
