Stem choice for this handlebar
AX Lightness or MCFK?
AX Lightness
44%
MCFK
56%
Total votes: 9
Luca79
by Luca79
So I've got a nice Schmolke TLO bar and can't make up my mind about the stem.
I've narrowed down between the AX Lightness Rigid and the MCFK.
Both nice, the AX is lighter and more expensive, but at this point I'll let the look factor be the deciding factor.
So, which one will look better in your opinion?
Thank you!
nvroadie
by nvroadie
MCFK all the way.
BRM
by BRM
You narrowed it down to 2 choices but now you can't make up your mind . . . . . :roll:
Buy a Goldfish, when it swims to the right you get the MCFK, when it swims to the left you take the AX.
:wink:
shimmeD
by shimmeD
Uno is the realworld solution to a 1st World problem.
There are a number of worthwhile similar solutions to the handlebars too.
Less is more.
casper3043
by casper3043
shimmeD wrote:Uno is the realworld solution to a 1st World problem.
1st world can afford nicer looking stems than Uno
shimmeD
by shimmeD
:thumbup: I totally get it that there are more choices in First World
Less is more.
wheelsONfire
by wheelsONfire
MCFK or forthcoming THM Tibia
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
KCookie
by KCookie
wheelsONfire wrote:MCFK or forthcoming THM Tibia
Can't seem to make up my mind if I like the THM, the front just looks weird.
Do like the MCKF though.
Luca79
by Luca79
MCFK seems to be the most appreciated... still tempted by the AX which is 10 grams lighter!
Valy
by Valy
I like AX more.
Kayrehn wrote:Mcfk for matching weave
that
4ibanez
by 4ibanez
We all ask ourselves these questions now and then. Ultimately can you be happy with your 2nd choice? It seems like you want someone to convince you to buy the AX, so I'll say "do it"! Mine has been fine...imo looks great and no issues whatsoever with function/flex at my 79-80kg.
Luca79
by Luca79
Thank you for all the suggestions so far :)
