130 BCD crank w/ 52/36 chainrings?
jbaillie
by jbaillie
Hoping someone can shed some light on this for me.
Elsewhere in the forum I've seen it said that 38T is the smallest inner ring you can do on a 130BCD crank. But I came across this from Chain Reaction which allows you to select a 130 BCD crank with semi-compact (52/36) rings. Is this right, or is it just an error on CR's part? http://www.chainreactioncycles.com/us/en/campagnolo-athena-11-speed-groupset/rp-prod139946
(see image below)
I have an old SRAM Force crank on my road bike running 53/39 and I'd love to go down to 52/36 but be able to keep my current crank arms. I know the ad is for Campy but that doesn't seem like it should impact how small you can go on the inner ring. Searching for a 52/36 130BCD set on eBay doesn't yield any results. Any ideas?
chazmtb
by chazmtb
I think that's a web error. Smallest 130 bcd is 38t. Any smaller and the bolt spacing would be in the teeth of the chainring.
Attermann
by Attermann
Campagnolo use 135 bcd, so it must be an error
stockae92
by stockae92
the smallest chain ring for 130BCD mentioned was 37T but it was never materialized.
i am still riding 53/39, my next bike will definitely has 50/34 though ... LOL
Another option is run a bigger cassette, but that might run into derailleur issue and likely to require a new rear derailleur for anything bigger than 28T
mythical
by mythical
To my awareness, this is the only 36T in 130BCD and it's integrated into the spider.
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
deek
by deek
Not sure if it's easy to actually purchase, but assuming you have the Force cranks with a removable spider, you could just buy a 110BCD spider and keep the arms.
ooo
by ooo
you can make 52/36 double using 130/74 triple crankset and 36T in 74mm BCD
Stronglight Dural 5083 Silver 74mm Shimano Triple Inner Chainring - 36T (265010)
Stronglight Zircal 7075 Silver 74mm Triple Inner Chainring - 36T (261015)
jbaillie
by jbaillie
deek wrote:Not sure if it's easy to actually purchase, but assuming you have the Force cranks with a removable spider, you could just buy a 110BCD spider and keep the arms.
Nowadays this would be feasible, but my cranks are older and the arms & spider are one piece.
New Force cranks
My version (mine are not compact obviously)
DartanianX
by DartanianX
Rotor make a 53t 110BCD chain ring paired to a 38t inner ring.
Sent from my Pixel XL using Tapatalk
mythical
by mythical
A separate 36T chainring on a 130BCD isn't possible basically because the teeth/chain interferes with the chainring bolts.
When the need for chainring bolts is eliminated, e.g. by integrating the them with the chainring and spider, then there is just enough clearance without having to resort to non-standard (read: smaller) chainring bolts.
RideWert.com
