It is currently Sat Jan 20, 2018 4:35 pm
Post new topic  Reply to topic  [ 53 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Zipp 454 NSW reviews
PostPosted: Sun Mar 19, 2017 5:40 pm
Beaver wrote:
In addition to the 25mm tires they should have tested the recommended tire size. The CLX 64 suffer a lot with wide tires
thumper88 wrote:
This part is the only thing he's right about -- and it's one huge reason the test is nearly useless. That "25m but really sometimes 29mm" tire stalled out a lot of wheels and at really shallow angles....and it probably had a really bad shape in addition to a bad size for stalling wheels.
But the roval clx is probably the widest wheel in the test (21/29.9) and it was second worst at 5deg. They designed it to be this wide especially to accommodate wider tires and minimize the aero hit.
Also I call BS on 35W difference between the roval and enve at 5deg yaw. Just think about it, even at 30 mph, that's crazy.
PostPosted: Sun Mar 19, 2017 6:53 pm
You're not the only one!
5 star and bespoke cycle tours in Majorca
Cycling related videos and reviews
PostPosted: Sun Mar 19, 2017 9:58 pm
Online
Some time ago GCN did a test : "stock" alloy wheels vs Zipp 808 @ ~ 41 km/h. Power needed went from ~380w to ~345w, so about 35w gain, so, no way there is 35w diff between the Rovals and the Enve's in real world circimstances.
https://www.youtube.com/watch?v=pUdC3mrHcc8
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
PostPosted: Mon Mar 20, 2017 5:28 pm
The bike radar review has some seriously questionable data in it. If I saw that data in my professional capacity I would dismiss it - the explanations they give about "aerofoils" stalling makes me cringe!
The vast majority of drag reduction comes from how deep the section is. The use of a "toroidal" profile is not going to make much difference in comparison to the section depth. There are also marginal gains to be had from the spokes but it is only small when the wheels are deep.
I have tried to explain in this video the aerodynamics behind wheels as opposed to picking an outright winner. It's long but quite in depth
https://youtu.be/BUih_emc54M
Hambini
The science behind Aero Road wheels!!
Ceramic v Steel Bearings: The Truth
Visit the Hambini Website
PostPosted: Mon Mar 20, 2017 6:38 pm
Specialized most definitely did not design the wheel for extra wide tires. For aerodynamics, the shape of it wants 23mm or so, with a decent profile. Look at the tunnel data from blather about bikes... the s-works 22mm works the best, the 24mm next best.
It's widest well back from the tire, unlike the slab-sided designs of say zipp and HED. You want the wind to flow around the leeward side and stay attached... in this case you want to try to keep that section shape looking like an aircraft wing rather than the body of a wasp.... smaller tire will do that, 25mm and up creates a hollow right behind tire on leeward side and the wheel stalls out. And the effect is magnified the further the apparent wind direction shifts from zero degrees.
Same thing happens when you go too large on a Zipp but likely the U-shape is at least somewhat less susceptible to that effect, up to a certain point in tire size.
This likely explains this BS results in this test.
PostPosted: Tue Mar 21, 2017 5:29 am
Moral of the story - forget Zipp! Keep thousands of dollars in your pocket and use pocket change for modern ~ 30mm aluminum wheels www.novemberbicycles.com/blog/2017/2/9/ ... lloys.html
PostPosted: Tue Mar 21, 2017 7:32 am
Best part of that article above is the comment saying that '10mph wind is serious'.
I want to move to wherever that guy lives :lol:
So these HED 6/9s according to Bikeradar are the business then if you want a fast wheel and are priced out of ENVEs. Interesting. Just a shame about that ugly ass alloy rim. Aesthetics are important of course, but if you're purely looking for a fast beater wheel then it's hard to argue against the HEDs.
PostPosted: Tue Mar 21, 2017 8:13 am
Given their total lack of credibility in these kind of tests, I wouldn't make any decisions based on them if I were you.
I remember they did one on aero helmets a while back and rubbished anything Giro. Giro went apeshit and they had to issue a statement.
I mean the guy says Campagnolo wheels would be 'cannon-fodder' for Christ's sake, I stopped listening at that point.....
There are no new unread posts for this topic. The Value of Bike Reviews
[ Go to page: 1 2 3 4 ]
RyanH
45
3204
Sat Dec 30, 2017 1:09 am
c60rider View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Carbonsports Lightweight RENNBÜGEL drop bar - any reviews?
Johnny Rad
Mon Feb 13, 2017 7:56 am
KCookie View the latest post
There are no new unread posts for this topic. Saevid Alien Saddle...Reviews/Experience
Squashednuts
11
1060
Sun Dec 03, 2017 7:04 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Proper Negative Reviews For Boutique Parts
KWalker
9
1574
Tue Aug 08, 2017 3:03 am
Ahillock View the latest post
Users browsing this forum: Bing [Bot], coriordan, Imaking20, LAN and 42 guests
cron
