It is currently Thu Jan 18, 2018 12:46 pm
Post new topic  Reply to topic  [ 67 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Tue Jan 31, 2017 10:37 pm
shinzomaeda wrote:
Why not mount it on the lower bolts, so its even with the bars? Seems silly to buy an S5 with all of the aero advancements and clean front end and then funk it up with a mount that posts the Gamin up into the wind like a sail.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
http://www.skratchlabs.com
2015 Specialized S-Works Allez
2015 Specialized Venge Pro
PostPosted: Wed Feb 01, 2017 7:07 am
glam2deaf wrote:
I recently found rec-mounts via instagram. Haven't tried them personally, but they look good to me. There are also other options for other bars and computers. https://www.rec-mounts.com/products/cervelo/garmin/
They have exactly the right idea. Just what I'm looking to do.
But so ridiculously ugly. It's like it was made on a gameshow that told you you have 10 minutes to make a mount from anything you find in a garage.
And they're not shy about charging you £60 too.
Thinking of some kind of bodge now. Imagine this, but longer, strapped/taped (maybe with a little rubber wedge) to the underside of the stem.
Probably a shaky mess :|
PostPosted: Wed Feb 01, 2017 7:58 am
CrankAddictsRich wrote:
Because you can't hit the start button with it lower?
New garmin mounts sit the unit higher as well.
Official cafe stop tester
PostPosted: Wed Feb 01, 2017 10:55 am
Correct, I had problems accessing the buttons when mounted lower.
PostPosted: Wed Feb 01, 2017 11:05 am
Shinzo, what if it was touchscreen, like the 820? Would it fit? Would be useable too.
PostPosted: Wed Feb 01, 2017 11:08 am
Good point! When I get home tonight I'll swap it over to lower position, extend it out, measure and take a picture!
PostPosted: Wed Feb 01, 2017 11:10 am
Omg! I've just read that again and sounds wrong !
PostPosted: Wed Feb 01, 2017 11:11 am
So wrong, but so right :D
PostPosted: Wed Feb 01, 2017 11:14 am
Lap and start / stop buttons ARE on the bottom end on an 820.
Touch screen or not doesnt come into it.
Ive had older mounts not take my 820; maybe the mounting lugs are slightly off set from middle on the newer garmins :noidea:
PostPosted: Wed Feb 01, 2017 11:38 am
Shame about the 820 buttons. There's goes another idea..
Might end up with one of those rec mount things.
/shudder
PostPosted: Wed Feb 01, 2017 1:05 pm
Ahhh. I have an 820 and I use the Barfly Fizik mount on my bikes with S-Works bars. It sits flush and I can still use the buttons easily, but maybe the pointed angle of the S5 bars make it trickier and the Fetha isn't quite as long. Can you get the Fetha in different lengths? I'd contact them... maybe they can develop an S5 specific model. It seems like something that is missing form the market and could be a great business oppurtunity.
PostPosted: Thu Feb 02, 2017 2:53 am
PostPosted: Thu Feb 02, 2017 10:04 am
I checked mine last night, by mounted off the bottom stem bolts and it doesn't fit my Garmin 520, I have the short one. Perhaps the long one would be better, but I can't tell at the moment. Sorry I can't help much more.
Miles
PostPosted: Thu Feb 02, 2017 10:10 am
No worries, thanks for checking. Still waiting on a reply from Fetha on it. Probably be around 3 weeks for an email reply judging by last time :D
PostPosted: Thu Feb 02, 2017 10:30 am
That's a shame, he was pretty helpful when I dealt with him before, maybe a busy time? Best of luck, would be interesting to see the solution when it's solved.
There are no new unread posts for this topic. K-Edge Garmin Mount - Regular vs XL
ipenguinking
9
833
Thu Dec 28, 2017 7:22 pm
dim View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
There are no new unread posts for this topic. Canyon H31 mount screw
Kristian78
Sun Sep 10, 2017 7:59 am
MayhemSWE View the latest post
Users browsing this forum: Vermu, Yahoo [Bot], Zakalwe and 34 guests
