It is currently Wed Jan 17, 2018 2:09 am
Post new topic  Reply to topic  [ 71 posts ]  Go to page Previous 1 2 3 4 5
 Post subject: Re: Scott foil '16
PostPosted: Thu Jun 22, 2017 5:38 pm
ab01ns wrote:
I'm loving my new foil.
Great looking F01L! Really digging the orange and aggressive drop.
Can you post a pic zoomed in the top tube / head tube / stem area. Looks like there's a little nub on the frame to matches up to Scott's uniquely-shaped stem spacers.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Thu Jun 22, 2017 8:50 pm
Anyone runniung an Antares 00 with their Foil? I just installed one, first ride, and my bib shorts are worn. I assume it's the carbon rail (seen it discussed here before) rubbing on the shorts.
PostPosted: Thu Jun 22, 2017 9:41 pm
ab01ns wrote:
I'm loving my new foil. Now to save up for ee brakesImage
Sent from my Pixel XL using Tapatalk
Wow, spectacular!! Could you post a more close up pic of the stem / frame area? Isn't it possible to reinstal the factory cap at the rear of the stem? Or use a regular topcap / dustcap (I know, it's 1 1/4 :? ) I tought I once saw a pic of a foil without the special topcap and with only a round dust cover over the headset.
Edit : this is one of the pics I found of Gerrance '16 Foil. Could be an idea :wink:
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
PostPosted: Fri Jun 23, 2017 1:46 pm
If anyone is interested, I have just taken delivery of a new pair of handlebars (Syncros intergrated). These newer bars, now come with enough room for the Di2 end cap junction box to be installed, they've also gotten rid of that stupid annoying trap door, and so you can now use a much lighter Garmin mount. For those who might be interested, I will post some pics a bit later...
PostPosted: Wed Jun 28, 2017 10:54 pm
Sergio76 wrote:
:idea:
Brand: Scott Type:Foil
Final weight: 7,6kg.
Frame Scott Foil 56 (L)
Fork Scott Foil
Headset Scott Foil
seatpost clamp Scott Foil
Seatpost Scott Foil Carbon
Seat Scott Foil Syncros
Stem Scott Foil Syncros 130 mm
Bar Ritchey Evo Curve Black Wet 44 cm
Bartape Lizard Skin
bottle cages and hardware Elite Cannibal
Brakes Ultegra Direct Mount 6800-R
Front derailleur Shimani Ultegra 6800
Rear derailleur Shimano Durace 9100
Crankset Rotor 3D+ InPower
Bottom Bracket Rotor Ceramic
Chainrings Rotor Q-Ring Red 50x34
Chainring bolts Rotor
Chain Shimano Ultegra
Shifters Shimano Ultegra 6800
Cassette Shimano Ultegra 6800
Wheels: Shimano Durace 9100 C24
Inntertubes Michelin
Tires Veloflex Corsa 25 mm
Pedals Look Keo Blade Carbon
garmin/computer mounts Garmin 500
I'm looking into buying a Scott Foil, your is size large how tall are you ?? What about inseam of legs ? How tall is that saddle height ??
thanks regards !!!
PostPosted: Thu Jun 29, 2017 1:04 pm
Update!!!!
PostPosted: Thu Jun 29, 2017 3:21 pm
Beautiful Foil! Really nice choice of componts . One question. Is that a 25mm setback seat tube? Great stuff :)
PostPosted: Fri Jul 28, 2017 9:15 am
TurboKoo wrote:
Small update with new handle bar and wheels
What Garmin-Mount are you using here? I`m looking for exactly this solution
PostPosted: Fri Jul 28, 2017 10:45 am
I use Fetha mount.
PostPosted: Sat Aug 12, 2017 10:24 pm
One question, anyone knows what model of quarq powermeter fits at foil '16 frame ???
PostPosted: Sat Aug 12, 2017 11:55 pm
I have one one these....
Twitter: @FormerTTchamp https://twitter.com/FormerTTchamp
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
6776
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Scott Foil HMF Build
ab01ns
Sat Dec 16, 2017 5:30 pm
banik69 View the latest post
There are no new unread posts for this topic. 2018 Scott Foil disc
Renne
13
2734
Fri Oct 06, 2017 7:44 pm
TonyM View the latest post
There are no new unread posts for this topic. Please help with scott foil model year
kelih
Fri Jun 23, 2017 3:11 pm
kelih View the latest post
There are no new unread posts for this topic. Scott foil frame finish
toastie
Mon Apr 03, 2017 6:18 pm
toastie View the latest post
Users browsing this forum: Alex2012, Bing [Bot], Google [Bot], Malammik, Rocket-Sauce, Yahoo [Bot] and 34 guests
cron
