StrongLight Pulsion .. it's arrived
Delpi
by Delpi
A new generation of Crankset ....
BB: ISIS
Lenght: 170, 172.5 o 175mm;
Chainring: 42/52, 39/52, 39/53 o 39/51;
BCD 130mm only
:shock: Claymed weight: 450gr (with chainring 53-39 and all bolts!!!)
Price: Euro 539,99 :cry:
and now it's arrived ... :)
www.bikeonline.it (... 460,00 Euro )
and now tell me ... what do you think about this strange crankset??
Ciao Zauri
Delpi
by Delpi
:shock: :shock: :shock: :shock:
... I am shocked ... what is it??
Ciao Zauri
Delpi
by Delpi
This photo is better...
Stronglight Ultim (Developed for the best aerodynamism and output)
There are two different version:
ULTIME SINGLE (One chainring) ==>Trak Using
ULTIM DOUBLE (Two Chainrings) ==> Chrono using
BB: ISIS
Lenght: 172.5/175/177.5/180 mm
Chainring:
SINGLE: 46 - 48 - 50 - 51 - 52 - 53 - 54
DOUBLE: 52/42-52/39-53/39-51/39
BCD 130mm only
Claymed weight: 620gr (with chainring 53-39 and all bolts!!!)
http://www.xxcycle.com/cgi-bin/shop.pl? ... =98&PAGE=1
Ciao Zauri
spytech
by spytech
Delpi wrote:A new generation of Crankset ....
BB: ISIS
BCD 130mm only
but are they any good, and how about stiffness :?: answered my own questions at the bottom.
here is a better picture, but what the heck is that weird looking crank Image Image
ok guys i have some info and here it goes "More rigidly and more aerodynamically it does not go! The crank exceeds the new Dura Ace in things rigidity 2004, by your ingenious building method. Flat building method guarantees best aerodynamics. Ideally for time driving and Triathlon, where it depends on each second. Only ISIS kind of condition suitably. In the following variants with chain sheets available: Lengths 172.5/ 175/ 177.5/ 180mm, 52/42, 52/39, 53/39, 51/39 teeth weight: 630g of inclusive chain sheets and puller" it was in german. Image
i dont think it includes BB at that weight, but it sure does look cool. The pulsion crank is 460g and 550g for a triple chainring. they say its stiffer than any crank under 500g.
spytech
by spytech
here is their website http://www.zefal.com/stronglight/accueil.php
they are getting lighter and lighter - When is FSA K-force coming, i just might upgrade :D
HäddaFahn
by HäddaFahn
Pure Uglyness...if i look again i m getting blind....MEDIC! ! !
Superlite
by Superlite
I'm with you on this one. That is one ugly mother f%#$&*. :lol:
nzkiwiguy
by nzkiwiguy
I don't think it is ugly. It would negate the need for aero rings on a TT bike which add weight as well. Wonder if it is UCI legal? ir if there is any restrictions in this area.
Superlite
by Superlite
And those HUGE carbon arms dont? :roll:
Plus side winds will kill on those things.
Joel
by Joel
1) It's the most ugliest bike part i've ever seen
2) When they try to make something aero, it's stupid to make a hole in it
nzkiwiguy
by nzkiwiguy
sure they add weight but is it less than a solid FSA or shimano ring?
As for cross winds it would not affect it anywhere near as much as a disk on a TT. or a solid outer ring.
I certainly would not use them on anything but a TT or crono bike
Superlite
by Superlite
It's just a bunch of marketing hype crap. Like you need the whole friggin crank arm for it to be aero.
Why wouldn't it affect as much as a solid outer chain ring? Theres even more surface area on that crankset because of the huge arms!
Plus I bet it slower then a conventional crankset with a TT ring. The boundry layer is friggin huge, plus the crank arm and chain ring wedge together, probley making more wind resistence, where as on a conventional crankset the arm and chainring flow together, no parallel surfaces making turbulence.
And Joel, you hit the nail on the head, the hole in it makes it even less aero. Marketing crapola is what it is my friend. And it has a bad case of the ULGIES! :lol:
spytech
by spytech
i dont think the crank is as ugly as some of you may state - we have to see it on a bike, its stiffer than a DA 04 crank (so they state) its a little bit heavier, but about the same weight as a regular crank with a solid chainring. the crank has a coolness factor to it, i can tell you that. about aerodynamics i dont know, but i know the most areo shape would be a tear drop. i dont see any testing on this crank, so we dont know if its more or less aero than a standard crank with a solid ring. :roll:
ras11
by ras11
Only the French could design something sooo F-Ugly. Some French butt monkey is laughing his head off right now. "I know, I'll build the stupidest looking crank, make it out of carbon, call it aero, and see who buys them. Ha.. Ha.. Haa.." :roll: Does anyone else get the feeling they are participating in a Monty Python skit.
There is no style points awarded here. Points are awarded for bravest design, 100 points. Points maybe subtracted, up to 250 points, if these cranks a) only fit special super heavy BBs b) break/delaminate soon after installation c) during the coarse of failure cause serious injury d) if all the kids think they are 'cool' e) have the largest recorded q factor. Points will be added if history records these cranks as the worst cycling equipment ever made (100 points). If a single pro rider uses them in the Tour de France (10000 points).
:-) Toys-R-Us
Superlite
by Superlite
It's funny, this weekend in NM I saw this total fruit ride a TT bike, with a fake disc wheel in a crit! These cranks are something that guys like that want. Ahhhh, the fruits of cycling. :lol:
