It is currently Sun Jan 21, 2018 11:50 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sat Sep 03, 2016 6:43 pm
So I managed to break my scapula and crack a rib in the process of gouging the rim of my Jet 6 and tearing the sidewall of my one-week-old Corsa G+. Do you think it can still be used after some sanding and polishing?
PostPosted: Sat Sep 03, 2016 8:05 pm
Sorry to hear about your injury. I hope you're back on the bike quickly. No problem with that rim. A quick grind and it will be fine.
PostPosted: Sat Sep 03, 2016 9:20 pm
What the heck did you run into? Ouch.
The damage in the first photo - I would want to make sure the clincher bead isn't compromised. That gouge also gets into the brake track a fair way. You might have to run your brake pads a little lower than optimal. The other side is no problem.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Sat Sep 03, 2016 10:32 pm
Geoff, Mr.Gib,
Thanks for your comments. I will be breaking the Dremel (with a polishing wheel) out once I regain the use of my injured shoulder.
The damage was caused by riding off the raw edge (no curb) of the tarmac surface at a shallow angle.
There are no new unread posts for this topic. Carbon rims with alloy brake track
in Everything wheels
dmulligan
Sun Jul 16, 2017 8:45 pm
Multebear View the latest post
There are no new unread posts for this topic. How are older Zipp 404 clinchers - aluminum brake track?
AJS914
Thu Mar 02, 2017 6:43 pm
gitsome View the latest post
There are no new unread posts for this topic. Shimano DA hydro hose replacement : how much brake fluid needed?
Delorre
Mon Oct 30, 2017 4:04 pm
JayUK View the latest post
There are no new unread posts for this topic. 24h Alu rim recommendation for track bike?
Monkeyfudger
Wed Sep 06, 2017 1:49 pm
morganb View the latest post
There are no new unread posts for this topic. South east velodrome in the US for track camp
LouisN
Mon Sep 04, 2017 12:35 am
FIJIGabe View the latest post
Users browsing this forum: Gutsyfungus, taztaylortaz and 6 guests
