It is currently Tue Jan 16, 2018 10:55 am
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
PostPosted: Wed Feb 04, 2015 3:15 pm
Hello
My current set up is Ultegra 6700 (ten speed). I'd like to upgrade to 11 speed so was wondering if I could do this with new shifters and cassette only. Has anyone tried this successfully? Or do I need to get mechs as well?
Any help appreciated
Cheers
Jamie
PostPosted: Wed Feb 04, 2015 4:20 pm
You need a new chain. You will also almost certainly need a new rear wheel, or a new hub that can be re-laced to your existing rim, or if you just so happen to have a hub that can have it's freehub body upgraded. I don't know about Shimano cable pull differences between 10s and 11s so I can't speak for the rear derailleur.
PostPosted: Wed Feb 04, 2015 4:27 pm
New right shifter, new chain, new cassette.
Cassette: You can get an Edco Monoblock, or an Ultegra cassette that's been machined for 10sp freehubs- there's someone on ebay offering these.
In case you have Mavic wheels, Mavic 10s freehubs will also fit 11s cassettes.
Generally though, 11s cassettes are too wide for 10s freehubs.
PostPosted: Wed Feb 04, 2015 4:40 pm
Thanks for the replies
I should have said, I have a Mavic wheel which will take an 11 speed cassette, so that will be fine.
I thought the rear mech might need changing as well- I'll give it a go without though first
PostPosted: Wed Feb 04, 2015 5:58 pm
The only setup I'm aware of that you can do this is Sram. For example, my TT bike is using 10 speed derailleurs with 11 speed everything else for an 11 speed setup. Shimano and Campy require you to upgrade the whole setup.
Moloko Plus 6.24 kg
"We haven't located us yet"
PostPosted: Fri Feb 06, 2015 3:10 pm
I thought that Shimano didn't change the derailleur actuation ratio, mtb 9 speed = road 10 speed = road 11 speed.
Only MTB 10 speed is different.
PostPosted: Fri Feb 06, 2015 10:10 pm
Do you mind sharing the link to it? I can't seem to find it on eBay or Google. Maybe I'm not searching with the right keywords?
PostPosted: Fri Feb 06, 2015 11:57 pm
So with my SRAM Red 10 spd, I only need a cassette, chain, and right shifter? If so, that's not too bad. All my wheelsets are 10/11 spd.
PostPosted: Sat Feb 07, 2015 3:37 am
SRAM can upgrade only shifters and cassette.
Not true with shimano.
rear D is different, front cable pull is different... it will not work well if it does work at all.
You can re-use your brakes and crankset.
Need chain, cassette, derailleurs and shifters to the best of my knowledge.
PostPosted: Tue Feb 17, 2015 2:16 pm
Is some one find link to buy modified ultegra cassette ?
On ebay it stop to sell it :(
Thanks
PostPosted: Tue Feb 17, 2015 8:51 pm
I heard they did change it for 11spd but no idea how much or which way.
formerly rruff...
PostPosted: Tue Feb 17, 2015 9:01 pm
Apparently they should work
Velonews wrote:
Dear Lennard,
Will Shimano’s 6700/7900 rear derailleurs work with the newer 11-speed 6800/9000 shifters and 11-speed cassettes?
― Alex
Dear Alex,
Yes, Shimano Ultegra 6800 and Dura-Ace 9000 11-speed shifters and 11-speed cassettes work flawlessly with Shimano Ultegra 6700 and Dura-Ace 7900 10-speed derailleurs. And since the 11-speed levers require substantially less shifting force, you should get a lighter shifting feel as well as an extra gear!
― Lennard
http://velonews.competitor.com/2015/02/ ... ing_361088
My Dengfu FM098
PostPosted: Tue Feb 17, 2015 10:11 pm
That's cool... it wouldn't be the first time if he was wrong, but I hope he is right.
formerly rruff...
PostPosted: Fri Feb 20, 2015 7:36 am
VN yanked Lenny's reply. Maybe he was wrong. Or maybe Shimano got all pissed off.
PostPosted: Fri Feb 20, 2015 7:40 am
He guys, where is this e-Bayer selling modified cassettes?
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
There are no new unread posts for this topic. Campy upgrade, keep cassette and chain?
Alexandrumarian
7
641
Wed Aug 02, 2017 6:55 pm
c60rider View the latest post
There are no new unread posts for this topic. Retrofitting etap in to Campy 10 speed shifters
uraqt
Tue Jul 11, 2017 7:13 am
motorapido View the latest post
There are no new unread posts for this topic. Servicing 11 speed Campagnolo Ergo power shifters?
wilwil
Thu May 18, 2017 10:18 am
graeme_f_k View the latest post
There are no new unread posts for this topic. Attachment(s) Adding 16T to 11-xx 11 speed cassette
efeballi
12
1032
Sat Oct 07, 2017 10:10 pm
efeballi View the latest post
Users browsing this forum: Bing [Bot], CarlosFerreiro, Google Adsense [Bot], jacobeh, sharkman, sungod and 42 guests
cron
