Best cheap option, rigid fork 29´er....?
Easer
by Easer
-Hi, sorry if asked before, I tried to search but didn´t find any, but I guess the question has been asked before....
What options is there with regards to a reasonably priced rigid fork for a 29´er, I have been looking at the Trigon but would like to see if there´s anyone with an different opinion/option....???
Bjarke
DanW
by DanW
Trigon, Hylix or Exotic. Exotic will be the heaviest and more importantly cheapest which is why I went for it. Also preferred the aesthitics of the straight legs rather than curved. A second hand Niner might also be an option. I figured that there can only be so much performance difference between rigid MTB forks so just go for the cheapest one you like the look of and has a durable reputation = Exotic :D
yourdaguy
by yourdaguy
The main advantage of the Niner is that they do not bend much when braking. I know they are way expensive, but if you can find a used one, it is the way to go.
For certain parts stiffer is more important than lighter.
AdyM
by AdyM
Both Superstar components and On One have cheap carbon forks, for £180 and £150 respectively
TheRookie
by TheRookie
And Exotic carbon, I suspect they are all the same parts under the logos.
