It is currently Sat Dec 16, 2017 8:00 pm
Post new topic  Reply to topic  [ 85 posts ]  Go to page Previous 1 2 3 4 5 6 Next
 Post subject: Re: New Stainless Build
PostPosted: Wed Jun 18, 2014 7:43 am
Aimar from Amaro also offered me the Grammy for my Amaro Loren But i like the Look of straight blades a bit more.
Ok if You Look sharply on the scale, 50 Grams Are 50 Grams ;0)
I will also so use a deda Zero 100 ( custom paint by amaro ) combined with my favorite handlebar the 3t rotundo Ltd which saves 100 Grams to an alloy deda bar ;0) for Example a deda Newton anatomic.
BACK IN BLACK
PostPosted: Wed Jun 18, 2014 12:41 pm
Nice frame!
Please don't search too hard for that Dark Metal cockpit. The color always dissapoints. Custom painting the stem and bars might really suit this frameset.
PostPosted: Wed Jun 18, 2014 1:45 pm
Agree with Stoli. On my last steel build I had the cranks, seatpost, brakes, bottle cages, headset and stem all polished. I've had the deda metal finish before but it doesn't match the other components.
PostPosted: Wed Jun 18, 2014 1:55 pm
May just go with the original plan for Fizik alloy bars & carbon post then. That is if it turns up on time.
PostPosted: Wed Jun 18, 2014 3:37 pm
ultimobici wrote:
It isn't a stock Acciaio Stainless. The regular version has a normal 1 1/8" straight head tube and uses a Columbus Minimal fork. This has not only a 44mm head tube to accommodate the tapered fork, but also has a slightly larger diameter down tube as well. So it's like a Super Acciaio Stainless.
Many jealous.
I built up my Super Acciaio 3-4 months ago and love it, but I was pulling my hair out deciding between Stainless Acciaio, the Super or a Genisis Volare Team. Now you've gone and combined the best of all three of those bikes.
PostPosted: Wed Jun 18, 2014 9:27 pm
OK. Stems -
Deda Zero 100 DMP
Fizik
Deda Super Leggero
Bars will be mated with Zero 100 for Deda and Fizik R3 for Fizik, and all will be in Black. Post is a choice between Superzero or Cyrano Carbon depending on the bar/stem make. Saddle will be either an Arione CX or Arione 00. Wallet will likely decide that!
As for the polished bits, I've tracked down some silver UT cups so I'll use a Record 11 chainset. So other than the polished knuckles on the rear mech there'll be little to clash.
Thoughts?
PostPosted: Wed Jun 18, 2014 10:04 pm
I like the Fizik kit....:beerchug:
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Jun 19, 2014 1:46 am
whichever you do... make it black. the polished stem doesnt match the stays and, as a result, clashes rather noticeably.
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Thu Jun 19, 2014 8:24 am
The Fizik for sure.
PostPosted: Thu Jun 19, 2014 8:42 am
can you tell us something about the front derailleur hanger and the derailleur cable stops
it looks like they are to be bolt on; are they columbus parts ?
PostPosted: Thu Jun 19, 2014 9:40 am
+1 on the Fizik
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu Jun 19, 2014 4:24 pm
Love the naked TT stripe. Currently waiting on an IF SSR Max with a 44ht and getting I patient every time I see another build!
PostPosted: Thu Jun 19, 2014 5:23 pm
Here you go. Both are bolt on fittings.
PostPosted: Thu Jun 19, 2014 8:02 pm
txs
do you know who is the manufacturer ?
PostPosted: Sun Jun 22, 2014 12:09 pm
txs
Front mech boss is branded Thecno, cable stop is an in house item.
There are no new unread posts for this topic. Budget Build: Single Speed 2002 Trek 5500 Conversion Build
chefczyk
7
1441
Fri Sep 22, 2017 6:01 pm
evan326 View the latest post
There are no new unread posts for this topic. Becoming an Old Man : Evo sub 6kg build
[ Go to page: 1 2 3 4 ]
prebsy
53
7626
Thu Apr 27, 2017 1:25 pm
prebsy View the latest post
There are no new unread posts for this topic. New Caad12 build
Hapsmo911
20
2155
Tue Oct 31, 2017 12:13 am
Hapsmo911 View the latest post
There are no new unread posts for this topic. aluminum ww build
Rubik
Fri Jul 07, 2017 5:09 pm
HeluvaSkier View the latest post
There are no new unread posts for this topic. Pinarello F10 Build
Bridgeman
24
3123
Fri Dec 08, 2017 7:42 pm
TonyM View the latest post
Users browsing this forum: dudemanppl, mannequinforce, MrRobot and 23 guests
