It is currently Sat Oct 21, 2017 3:29 pm
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Tue Jun 03, 2014 1:44 pm
As short as you can find is my suggestion. I have bora 35's with a 20mm valve extender. It's more than long enough.
PostPosted: Tue Jun 03, 2014 7:50 pm
First, make sure you buy the type that relocates the valve core, not the type that just slides-over an open valve. I prefer the brass-bodied Vittoria ones: http://www.wheelbuilder.com/vittoria-va ... nders.html
Second, when you relocate the valve core, make sure that you use a few turns of Teflon plumbing tape on the threads of both the valve stem and the valve core. It is much better to make sure that you have a good seal before you glue-up the tire.
With respect to the length, the 30mm version should be the 'right' choice for you.
There are no new unread posts for this topic. Valve extender help
4ibanez
7
398
Sat Jul 01, 2017 6:29 pm
4ibanez View the latest post
There are no new unread posts for this topic. Grifo valve extension advice
alanmclean
Thu Oct 05, 2017 7:30 pm
alanmclean View the latest post
There are no new unread posts for this topic. Vittorio Corsa G+ tubular bulge at valve
NiFTY
7
999
Thu Feb 02, 2017 7:27 am
sungod View the latest post
There are no new unread posts for this topic. Sealant and Valve Core Extension on High-Profile Wheels
Lightweenie
Fri Apr 21, 2017 11:52 pm
beatle View the latest post
There are no new unread posts for this topic. srm crank length
simoncx
7
302
Tue Oct 10, 2017 4:23 pm
simoncx View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], jwfinesse, Miller, wingguy and 36 guests
