It is currently Thu Sep 21, 2017 2:43 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu May 15, 2014 11:50 am
Hi all,
I'm sure this topic has been covered previously but haven't been able to find a thread that includes clear instructions.
I have a Deda MNLink seat post as per the below link and I'd like to remove all the manufacturer logos. I'd like to end up with a matte finish plain carbon post. is that possible and if so what is the process?
Thanks in advance for your help.
http://www.dedaelementi.com/index.php?p ... 57&lang=en
PostPosted: Thu May 15, 2014 2:14 pm
1. Grab a piece of waterproof sandpaper, I like 240 personally.
2. Fill a bowl with water.
3. Dip the sandpaper in the water.
4. Start sanding down the logo's
5. While sanding down, clean the sandpaper and seatpost from dust, so you can see the progress.
6. Stop when the logo's are gone and you have a smooth finish.
7. Repaint is probably needed to make the seatpost fit again.
It's not that hard...
PostPosted: Thu May 15, 2014 2:45 pm
Are the Deda logos under a clear coat of any sort? If not, why not try acetone first? They should just wipe right off. You would only need to use sandpaper if there was a clear coat/finish of some sort.
PostPosted: Thu May 15, 2014 5:05 pm
Good point 53x12.
Has anyone else had any experience with trying to remove decals from current generation Deda products?
I'm not too handy with the DIY but from what I can tell it looks like the decals might be under a thin layer of matte clear coat.
PostPosted: Thu May 15, 2014 5:43 pm
it's really easy
wet sand with fine sandpaper
respray with clear coat
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. Removing logos from a veloce crank
TomColnago
Sat Jan 14, 2017 12:25 am
TomColnago View the latest post
There are no new unread posts for this topic. Taking painted logos off carbon wheels?
Bianchi10
Tue Mar 21, 2017 8:58 pm
culovero View the latest post
There are no new unread posts for this topic. Any easy way to remove white logos on carbon rims?
Shrike
Sat Jan 28, 2017 12:11 am
Broady View the latest post
There are no new unread posts for this topic. Removing external cable routing from carbon frames (Parlee)
grover
Thu Oct 13, 2016 3:04 am
kevosinn View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], gmarsden, Pschnei3, Relientk1202, springs and 34 guests
