It is currently Wed Jan 17, 2018 4:30 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3
PostPosted: Fri May 23, 2014 9:17 pm
Yes don't think about the the losses, think about having a straight chain with small steps around the speed you ride.
To me 52-36 & 11-25 is perfect for endurance (small ring) ans time trials (big ring)
While having enough top speed for sprints, and enough small gear for most climbs (not enough for walls with cobbles in Belgium tho :p)
Envoyé de mon Xperia Ray en utilisant Tapatalk
PostPosted: Sat May 24, 2014 7:07 pm
This might get more interesting once people record gear data with di2. If I were you I'd try and record a few rides and look at time spent at certain speeds (not average speeds) in WKO+ or GC. Then you can figure out what gear you would have been and how often you'd have to shift between chainrings.
That's pretty personal as it depends on power, power to weight, prefered cadences and what not.
When I last looked at it, it put me right between rings in a compact setup for some false flats I rode quite a bit where I live. I also used different wheels with different cassettes, and that somehow worked out better with standard gearing.
Long story short, use the gearing that suits your riding better, not the one that makes your bike lighter.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Sat May 24, 2014 11:15 pm
Personally I can't make compacts work for me the inner ring becomes pointless on everything but steep hill. To make more use of the inner I have found a new record 10 speed square taper chainset with 53/41 rings at a distributor. The last one too, mated to a 12-27T 11 speed cassette and I have the perfect gearing for me in suffolk. It's not light but that is almost that does not matter given the wheels I have just built for it.
36:25T is plenty for cobbled Belgian walls, I did them on 39:25T man that was hard and slow.
www.thecycleclinic.co.uk
PostPosted: Sun May 25, 2014 12:32 am
I did them with 39-25ish too! :)
I was using an old wheel with 9s on my 10s bike, worked surprisingly well without tuning.
But on the steepest section (28% I think) I hit 9 km/h minimum so I'm not sure if I would have made it without clips. But its fun!
Now I use 53-39 11-28 (10s) but the steps are way too big.
PostPosted: Sun May 25, 2014 5:11 am
Ill admit I run up to 34-32 gearing when grinding out hill repeats using a 6800 casette on a 9000 groupset, being 90kg every rpm of cadence I can have on my side is nice when going out to pull 1000m+ vert in a quick 40km ride. I like my knees ;)
Using Tapatalk
There are no new unread posts for this topic. Giant OD2 headset weight savings
haynesdavid1988
Thu Jun 22, 2017 3:18 am
haynesdavid1988 View the latest post
There are no new unread posts for this topic. Groupo Weight savings question
addictR1
Sun May 07, 2017 12:42 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Di2 RD won't move at all.
merser
18
1652
Fri Jul 21, 2017 7:42 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Cost savings building Tarmac UL Disc from Frame?
queloque67
Thu Oct 12, 2017 2:36 am
TonyM View the latest post
There are no new unread posts for this topic. Compact v semi compact
wilwil
35
2511
Thu Jul 27, 2017 11:05 pm
shimmeD View the latest post
Users browsing this forum: AZR3, CarlosFerreiro, darnellrm, Google [Bot], Hahaboy, KarlC, kookie, liam7020, Yahoo [Bot] and 34 guests
cron
