It is currently Mon Jan 22, 2018 3:58 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Wed May 14, 2014 12:43 pm
Does anyone know if this is available anywhere?
Or is it just for the pros?
46/36 is available in Ultegra, so I don't know why thay won't sell Dura Ace...
PostPosted: Sun May 18, 2014 8:37 pm
The Dura Ace rings are typically only for sponsored riders, though you can usually find them if you talk to the right mechanic at the right race.
For a 46 I don't think they add that much. Check out the Praxis 36/46 rings with the little adapter blocks that smooth out the cosmetic look and also stiffen the larger ring. They are better than anything else out there.
PostPosted: Mon May 19, 2014 9:52 am
Where can I find them for dura ace 9000-cranks?
PostPosted: Mon May 19, 2014 7:06 pm
Ugh. My error. I set mine up on a pair of 7950 crank arms. I like those crank arms better than the 9000's anyway, and they are much more resistant to rub marks and other cosmetic damage than the 9000's.
PostPosted: Wed May 21, 2014 9:54 am
Ok.
I am thinking of buying a 9000 groupset for my cx bike and need to find out what cranks to put on.
PostPosted: Wed May 21, 2014 6:51 pm
I believe your only non-Shimano choice is Rotor. If you do get Rotor rings, get the little blocks they sell that trim out the crank arms so it looks good, because they also provide a lot of stiffening support for the big chainring. They're about $65 or so extra but worth it.
PostPosted: Wed May 21, 2014 6:59 pm
Doval also make them, but they're even less round than Rotor :lol:
PostPosted: Thu May 22, 2014 4:14 pm
Just run the Ultegra 9000 crankset on the bike. It is excellent. You could also buy an ultegra 46T ring and run it on the 9000 arms. That's what the Pros have, the 46T rings are just left unfinished or are anodized to match the 9000 crank arm color.... same ring though.
PostPosted: Fri May 23, 2014 10:40 am
Are you sure they fit?
Anyway the colors don't match so I'm not really sure it will look that good. I can't find any pictures of this combo.
PostPosted: Fri May 23, 2014 10:45 am
This is what I am looking for.
It looks like no other chainring.
PostPosted: Fri May 23, 2014 2:15 pm
Email Shimano, you have nothing to loose.
Sent from my SGH-I337M using Tapatalk
PostPosted: Fri May 23, 2014 5:11 pm
Those are flat chainrings, not hollow ones, with the same kind of adapter that the chainring bolts screw into and finishes off the crank arm spider. Given that it's flat, it could be practically anything. I don't see any evidence that that's even a shimano ring.
You're talking about a fairly small large ring. With the stiffness contributed by the bolt adapters, any ring that fits will do a very good job for you. Has Shimano ever done a 46 in the hollow design? The last 46 I can remember was for 7800, which was a flat ring. There isn't much point in doing a small ring like a 46 in a hollow design -- it'll just get in the way of building ramps and such. This is a bike. And a cross bike to boot. Just put on the Ultegra rings and ride it.
PostPosted: Wed May 28, 2014 5:28 pm
That is exactly what I said it was, a flat Ultegra 46 T chainring that has been anodized a different color. It was DuraAce... but it really isn't. That's just for show. The Ultegra 46T are not hollow. Again, I would just run the entire Ultegra CX crankset. It looks great, is pretty light, and works flawlessly.
46T Ultegra rings run ~$146 retail. The entire crankset can usually be found for ~$220-$250.
PostPosted: Thu Dec 21, 2017 11:59 pm
Sorry for resurrecting a very old topic. But I actually have the exact same question. Well, I could live with this solution. So is it a Rotor chainring? Or how do I get my DA9000 chain set to look like this?
wrote:
PostPosted: Fri Dec 22, 2017 12:41 am
Shimano Ultegra 6800 11-Speed Outer Chainring Dark Grey, 46t for 46/36 with XTR M980 Bolt & Cap Set (may require modification)
-Deacon Doctor Colorado Slim
There are no new unread posts for this topic. [SOLD] Dura Ace 9000 165mm crankset 53/39
muffinman
Sun Oct 22, 2017 1:00 am
muffinman View the latest post
There are no new unread posts for this topic. Shimano DA 9000 vs 9100 crankset
Grimpeur
28
2683
Fri Jan 05, 2018 12:29 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Stages Shimano Dura-Ace 9000 power meter 1st gen.
wojchiech
Thu Nov 02, 2017 4:54 am
wojchiech View the latest post
There are no new unread posts for this topic. Shimano Dura-Ace 9000 mechanical partial groupset
wojchiech
Mon Nov 06, 2017 5:30 pm
There are no new unread posts for this topic. Shimano Dura Ace 9000 free hub body backward compatibility?
BeeBee30
Wed May 17, 2017 7:32 am
petal666 View the latest post
Users browsing this forum: No registered users and 2 guests
