Cracked Campagnolo Titanium Cassette carrier
jbf
by jbf
Has anyone ever seen this? Campagnolo 21-23-25 titanium joined cogs off a 11-25 Record cassette. I gave it a good cleaning yesterday and discovered the cracked cassette interface. Do you think this would hold up after it is torqued down or is it now a paperweight?
eric
by eric
Paperweight, unless you want it to fail when you're cranking out of the saddle on a 15% grade, causing you to smash your gonads on the top tube.
bikerjulio
by bikerjulio
Sadly it's a paperweight.
Yours is the first reported case that I've seen with Campy 11-speed in what, over 5 years now?
There's a thread discussing similar issues with Shimano DA 11-speed too.
Although some or most of those issues seem to involve big guys putting down a lot of torque in the low gears.
There's sometimes a buggy.
One.
bm0p700f
by bm0p700f
Not much of a paper weight though as those things are light. I hope mine does not give up as a full Ti cassette is expensive. New cassette time I'm afriad bad luck.
kode54
by kode54
you can just replace those three cogs in the set. use the rest of your cassette.
like others have said...i've never seen that.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
bikerjulio
by bikerjulio
OP just for the record, how big and powerful are you? It turned out that the first Shimano poster was an ex track sprinter.
Just asking.
One.
jbf
by jbf
bikerjulio wrote:OP just for the record, how big and powerful are you? It turned out that the first Shimano poster was an ex track sprinter.
Just asking.
I hate to admit it, I am a fit 55 year old 155 lb rider who does lots of miles but have never owned a power meter so cannot comment on power. Draw your own conclusions.
bikerjulio
by bikerjulio
well, good for you :D anything can be fixed now.
https://www.youtube.com/watch?v=8r9er8I_Fqs
One.
kbbpll
by kbbpll
What's with the scarring/pitting in four places around the surface? In the closeup it looks pretty nasty. Were you missing a spacer? If not, what did the spacer look like? Those teeth look pretty worn too - how old / how many miles on it? Had you ever serviced it before? When I cleaned my Chorus cassette for the first time after being built, one of the spacers came apart into three pieces in my hand, shop warrantied it. Said Campy told them the torque on the lockring was supposed to be 15 nm instead of the 40 (?) stamped on it. This makes me curious if it's an over-torqued issue. The crack and the scars make it look like it was really mashed.
Edit - sorry, I realize now that there is no spacer at the 25 cog.
Oswald
by Oswald
Teeth don't look worn to me. But might have been overtorqued, judging by the marks.
Max Gravity
by Max Gravity
If you can't warrant it I would try giving it as zap with a TIG welder.
Less torque more loctite on the aluminum lockring if you ask me.
Max Gravity, unfairly treated by gravity!
mrfish
by mrfish
Personally I wouldn't bother welding this given it's a part-worn cassette. Campag might warranty it, and even if they don't, it looks as though you got some distance out of the cassette. Certainly don't ride it. Talk to your friendly LBS, then if they can't help, buy another and move on.
Causidicus
by Causidicus
rijndael
by rijndael
Please explain the details that lead you to believe it's an installation issue, rather than a material issue.
kode54
by kode54
rijndael wrote:Please explain the details that lead you to believe it's an installation issue, rather than a material issue.
looks overtorqued. the small pitted marks around the contact surface look uneven and dug into.
