It is currently Wed Jan 17, 2018 4:16 pm
PostPosted: Mon Apr 28, 2014 9:47 pm
Have anyone try this DA9000 rear derailleur and DA9000 chain with SRAM XG-1190 cassette? If so, any problems or noises?
PostPosted: Tue Apr 29, 2014 6:48 am
Yes i have that combination without any issue. It's a quite common solution to the problem with the Dura Ace cassette (which there is a long thread about).
PostPosted: Tue Apr 29, 2014 7:42 am
Yep, I'll second that combo, all good here. :)
Ahhh, coffee & carbon
PostPosted: Tue Apr 29, 2014 3:59 pm
Good to hear. I ordered Sram cassette and will arrive end of this week, can't wait to test it out for myself.
Yup, the only reason I want to use this combination to solve creaking issue I have with 4 months bike with DA9000 groupo. Thanks.
PostPosted: Tue Apr 29, 2014 8:10 pm
Actually, you asked about using Xdome 1090, which is a 10-speed cassette, with DA9000, which is an 11-speed groupset. If that's the case, the answer is no, it won't work. You would need to have Xdome 1190, which is 11-speed compatible (if you want to maintain 11-speed compatibility, which, if you're spending the money on DA9000, I would assume you would want to).
PostPosted: Wed Apr 30, 2014 6:44 am
They all work with each other these days, SRAM22, 9000/6800 and Campy 11 cassettes seem to be interchangeable with each groupset.
PostPosted: Fri May 02, 2014 8:49 am
Yep, I use the 1190 cassette on both my wheelsets with DA9000 grouppo. Works flawlessly.
My Parlee Z1
PostPosted: Sat May 03, 2014 8:57 pm
I'm running 11 speed di2 with a sram 11 speed cassette without issue
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
12
1408
Mon Jan 30, 2017 8:45 am
Marin View the latest post
There are no new unread posts for this topic. Sram red rear derailleur issues
NiFTY
19
2331
Tue May 09, 2017 11:32 pm
Gearjunkie View the latest post
There are no new unread posts for this topic. SRAM etap rear derailleur
aerozy
10
831
Fri Nov 17, 2017 3:06 am
charlieboy52000 View the latest post
There are no new unread posts for this topic. Sram etap rear derailleur problem
srammer
Tue May 30, 2017 4:25 pm
sungod View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google Adsense [Bot], Lewn777, pratt, prebsy, Yahoo [Bot] and 39 guests
cron
