It is currently Tue Jan 23, 2018 9:28 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: torque wrench?
PostPosted: Wed Mar 12, 2014 12:36 am
Is it time to join the torque wrench generation? Or are torque wrenches for wimps?
http://djconnel.blogspot.com/
Fuji SL/1
 Post subject: Re: torque wrench?
PostPosted: Wed Mar 12, 2014 12:43 am
Vectors?
PostPosted: Wed Mar 12, 2014 12:51 am
AndreLM wrote:
Vectors?
Yes. To install them I used a 25 lb box of kitty litter mounted on an 11 inch pedal wrench. That should have worked. But power data are clearly low:
Single point from Vector is on heavy randonneuring bike, most others are on Ritchey Breakaway road bike. Strava data are low because weight doesn't include equipment (clothes, helmet, shoes, backpack).
Fuji SL/1
PostPosted: Wed Mar 12, 2014 12:56 am
Cool. Would love to see your conclusions (even if I do not plan to use them...)
PostPosted: Wed Mar 12, 2014 1:08 am
I need to put them up against Powertap on the same bike (requires pairing each with a separate head unit). But it may be a washer issue, not a torque issue. I didn't use any washers because on my crank, which is relatively flat, it didn't look like any would be needed.
Fuji SL/1
PostPosted: Wed Mar 12, 2014 1:26 am
You need to add about 2.5 lb. to your 25 lb. bag of cat litter to get the desired 25 ft lb. of torque with an 11 inch lever no?
PostPosted: Wed Mar 12, 2014 2:41 am
What you going to do with that 15mm crowfoot?
PostPosted: Wed Mar 12, 2014 3:29 am
Apply proper torque the Vector onto the crank.
PostPosted: Wed Mar 12, 2014 4:07 am
I pushed slightly to account for the difference....
But it seems a torque wrench might be a good idea in general for bolt-tightening. Or is that over-stated?
Fuji SL/1
PostPosted: Wed Mar 12, 2014 8:24 am
Got one (BBB) some time ago and found out that 5Nm is really not all that much. Didn't have any problems in the years without it, though.
PostPosted: Wed Mar 12, 2014 12:13 pm
Can't hurt to know how tight you've gone, at least if you decide to go more or less your decision is a bit more informed.
PostPosted: Wed Mar 12, 2014 1:07 pm
smart move DJ. your measuring your training precisely, might as well properly measure your bolt torquing. just think of all the other bolts you can now torque properly with peace of mind. DC Rainmaker has info on the proper torque values for the Vector.
PostPosted: Wed Mar 12, 2014 1:51 pm
For a person who torques bolts everyday, it might be a waste of time. For an item like Vector, it appears to be a must have [experience or not].
For a person who will spend $1700 for a set of pedals and buy a $50 torque wrench.........well that's just ludicrous. If I did not want to buy a good torque wrench, I would pay someone who would torque it down properly for me.
BTW, using a beam type torque wrench is only accurate if you are looking at the indicator straight on. Attempting to torque a fastener, hold the items, and looking straight on the wrench to get a correct reading, is like watching monkeys with footballs.
PostPosted: Wed Mar 12, 2014 4:56 pm
Well, to be honest I didn't buy the Vector. But the beam wrenches were specifically recommended to me as generally more useful than the click-type wrenches as long as you have line-of-sight. The click-type are better for working under cars, and I don't have a car.
It seems like the torque wrench is a good idea for someone not turning bolts on a daily basis. Even if it prevents one mistake it's worth the money.
Fuji SL/1
PostPosted: Wed Mar 12, 2014 5:15 pm
I have the Vectors and use the Beam torque wrench and crowfoot method. Having moved and installed my Vectors numerous times between my trainer bike and road carbon, I can say that the Beam+crowfoot method is workable, but probably not ideal or incredibly precise. I've had issues in terms of getting lower readings on one bike vs the other.
The challenge in getting a correct reading is being able to look straight on the gauge while tightening given the rotation of the crank set while trying to tighten. Subsequently, I've purchased a TEKTON click-type torque wrench from Amazon to use with the crowfoot. This combination does not work well given the overlap on the female end of the crowfoot due to the increased head size of the click-type torque wrench. I'd like to use this but I think another crowfoot type option would be required (anyone have any thoughts on this?)
There are no new unread posts for this topic. Look pedal removal - allen key vs pedal wrench?
mvcap
19
1675
Thu Nov 30, 2017 5:32 pm
Rick View the latest post
There are no new unread posts for this topic. What Happened to Over Torque?
Valbrona
23
2255
Tue Oct 31, 2017 8:32 pm
Miller View the latest post
There are no new unread posts for this topic. Torque number questions
Mtek
7
463
Fri Jul 28, 2017 3:47 am
Mtek View the latest post
There are no new unread posts for this topic. Ultra Torque L/H thread
beanbiken
16
998
Tue Jul 25, 2017 3:24 pm
AJS914 View the latest post
There are no new unread posts for this topic. Chainring bolts torque spec
oldnslow2
Sun Dec 10, 2017 11:46 pm
oldnslow2 View the latest post
Users browsing this forum: arthurf, dim, DurianGrey, liam7020 and 10 guests
