It is currently Thu Jan 18, 2018 1:02 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Tue Mar 04, 2014 2:20 pm
I'm building up an Madone 7 for a friend and installing an FC-9000 (Dura-Ace) crank in the BB90 bottom bracket. With the bearings fully seated, it appears that the leftside arm does not slide onto the crank axle quite as far as I have experienced on other bikes I have built in the past.
Researching BB standards, the BB90 appears to be the widest at 90.5mm for road.
Thus on a related note, Shimano also sells two (2) different crank fixing bolts. (Version 1 and Version 2). The difference is thread length. Version 1 thread length is approx 8.5mm and version 2 is approx 16mm. I am assuming the version 2 is for these situations where the slightly wider bottom bracket causes the crank arm to engage on the splines slightly less.
Waiting on the crank fixing bolt to arrive (ver 2), but asking for input to see if I'm interpreting this correctly. Engagement of the arm on the splines seems to be about half, although that appears to be per design?
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
PostPosted: Tue Mar 04, 2014 6:34 pm
Strange.
Give the DS crankarm a light tap with a rubber mallet--make sure it's all the way in there.
PostPosted: Tue Mar 04, 2014 8:12 pm
The crank fixing bolt is not designed to lock the crank arm in place. It's only used to apply the right amount of 'pre-load' on the bearings. The two smaller bolts in the crank arm fixate the crank arm on the axle.
So, basically, if the thread on your version 1 bolt engages, you should be fine. Just give the crank a tap like crimsonbadger says.
PostPosted: Tue Mar 04, 2014 9:04 pm
I recently did this on my 2013 Madone 5 (same BB dimensions). Give the crank a tap with a rubber mallet, and once through, secure the crank (as mentioned above).
There are no new unread posts for this topic. Trek BB90 + creaking Ultegra 6800 hollowtech 2. Anyone like a mystery?
alcatraz
11
1002
Fri Sep 08, 2017 3:27 pm
kwakekeham View the latest post
There are no new unread posts for this topic. What bottom bracket do I need
JScycle
Tue Oct 31, 2017 7:56 am
JScycle View the latest post
There are no new unread posts for this topic. GXP Bottom Bracket Assistance.
Y26
13
1087
Tue Jul 25, 2017 6:09 pm
Y26 View the latest post
There are no new unread posts for this topic. Bottom Bracket Drag
Ltoddokc
10
1620
Wed Oct 18, 2017 12:32 am
youngs_modulus View the latest post
There are no new unread posts for this topic. Bottom Bracket Assistance
JScycle
7
761
Sat Jul 15, 2017 1:11 pm
Users browsing this forum: Feddesman, izza, tnkn and 32 guests
