It is currently Fri Dec 15, 2017 7:29 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Tue Feb 11, 2014 9:33 pm
We all know that Shimano did not make a mid/long cage rear derailleur for the DA9000 level. However, I recently acquired an Ultegra 6800 GS rear derailleur, and I don't see why the long cage wouldn't work on my DA derailleur, other than the weight penalty.
With that in mind, does anyone know anywhere that makes, or would be willing to make, a longer RD cage? I contacted Fibre-Lyte, and they have no plans to make such a beast, and none of my searches have provided me with an answer.
Thanks.
PostPosted: Tue Feb 11, 2014 10:18 pm
Haven't you effectively answered your own questions: use a 6800 cage?
PostPosted: Tue Feb 11, 2014 11:45 pm
I wouldn't want to for the reason I stated in my post, the weight penalty.
PostPosted: Wed Feb 12, 2014 12:13 am
199g vs. 158g? Really? I know this is WW, but this is a bit much considering the variables. If you need a GS rear mech then you're running a big ass cassette (32?) which is already quite a bit heaver than the DA 11-28 equivalent. This leads me to believe that you're not running a compact (in which case you should) or you absolutely need a 32 to climb (in which case 30g makes no discernible difference until you shift some weight off yourself).
PostPosted: Wed Feb 12, 2014 1:01 am
I think 41g is significant given it's WW. More importantly, and I may be completely off base here, but even though the longer cage will give you more chain wrap capacity, I thought I read somewhere that the knuckle on the DA derailleur is different such that you won't have enough "B-tension room" to accommodate an X-large cassette.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Wed Feb 12, 2014 1:02 am
+1000 :noidea: :noidea: :noidea: :noidea: :noidea: :noidea: :noidea: :noidea: :noidea:
PostPosted: Wed Feb 12, 2014 1:35 am
Some people actually race their light bikes in difficult climbing races where low gearing is a benefit even for very fit riders.
I know someone who used a 32t cog with 7900 DI2 derailleur for one of those climbing races. With 7900 Shimano moved the pivot a little to make room for larger cogs. While the spec is 28t, 30t is easily doable and 32t with the right combination of getting lucky on your frame's derailleur hanger and twiddling the B screw.
Can you swap the 6800's cage onto the DA derailleur? While the longer cage surely accounts for some of the weight difference it wouldn't be all of it. The DA body will be lighter than the Ultegra one.
PostPosted: Wed Feb 12, 2014 1:47 am
I have the new Dura Ace 11 speed and I just put a 11/32 on with the reg derailleur. I had to adjust the B screw but it works just fine. I can post pic if you need.
PostPosted: Wed Feb 12, 2014 4:19 am
If push comes to shove, I will swap the Ultegra cage over. That being said, cdenloe, can you post the photo? I'm ordering my wife's 32T soon, and if it works on my bike, then it's all academic, otherwise, it's time to mod the RD with the Ultegra parts (which I'd rather avoid).
PostPosted: Wed Feb 12, 2014 7:54 am
As the length of the cage really doesn't play a very big part in how large a cog you can run with the derailleur, that comes down more to where the upper jockey wheel is placed in relation to the cassette. This is the main difference between a road and a mtb RD.
So, if you just move your RD a little further away from the cassette, you will be able to use larger cogs. If the B-tension doesn't do it for you, you could just have a new derailleur hanger custom made that does the trick.
If you're already researching custom made carbon fibre cages, this seems like a viable option.
Longer cages will most of all just let you chain cross more. If you're climbing 20% gradients I suspect you're an advanced enough rider never to venture into full chain cross big/big.
The Shivenge
PostPosted: Wed Feb 12, 2014 10:07 pm
K-Edge will modify a 9000 derailleur and install a mid-cage.
I already checked into it as I am considering doing the same.
PostPosted: Wed Feb 12, 2014 10:18 pm
What DMF says.
Unless you want to run a triple front, you don't need a long cage (to take up the slack chain), and it will not help you running a bigger cassette.
If you want to squeeze out the last bit of clearance after giving lots of B-screw, swap in a 10t top pulley cog.
Edit: Some clarification: the DA 9000 RD has a capacity of 33t. Take away 16t for the 50/34 compact front, and you have 17t capacity left for the rear. That is exactly what's needed to handle an 11-28 cassette. However, the capacity typically specs err on the conservative side, so you can usually handle a bit more. For a 32t bottom gear cassette, to be on the safe side with regard to chain tension, use a chain length as you would for 28t. That means you can not cross chain big-big, but who in their right mind would do that with a big cassette anyway.
If you run a standard 39/53 front you don't have those issues at all, because the smaller 14t front capacity leaves 2t extra for the rear, so you'll probably get away without running a short chain.
PostPosted: Wed Feb 12, 2014 10:37 pm
Makes sense. I'll see what's out there. Thanks.
PostPosted: Wed Feb 12, 2014 11:43 pm
Maybe I'm a thicko, but I got the GS version of the 6870 to run with an 11-32 cassette and a 52/36 chainset.
Largely because I wanted "just works", I admit.
PostPosted: Thu Feb 13, 2014 12:32 am
The other benefit to the mid-cage (other than running the 32 tooth cog) is that with more chain the bike works better while in the big ring.
This is important on bikes with 52/36 or 50/34.
When you race you end up going back and forth on a compact chainring set more than you do on a 53/39. The mid cage and longer chain allows to to cross-chain better.
I have set up a few wi-fli and 6800 bikes with mid-cage derailleurs.
I am considering going mid cage myself. I will probably get a 9000 derailleur and
have K-edge turn it into a mid-cage.
There are no new unread posts for this topic. Short cage or long cage RD for 32t cassette on single chainring?
Ed209
Thu Aug 03, 2017 9:54 pm
Ed209 View the latest post
There are no new unread posts for this topic. Ultegra 6800 long cage rear derailleur indexing issues
alcatraz
Fri Aug 18, 2017 1:17 pm
WinterRider View the latest post
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], itsacarr, nickf, ohhyeok90, sk1324, stockae92, wingguy and 48 guests
