It is currently Fri Jan 19, 2018 10:41 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sat Feb 01, 2014 12:27 pm
Hello!
My LBS installed a new Pro Stealth Evo integrated bar for me but have had problems getting the Campy Super Record 11 shifters to tighten. They claim the bars, being compact, have a smaller radius at the point the shifters tighten on the bar and there's not enough thread to tighten them properly. I can find pics of Campy shifters on these bars but only the ergo version. Anyone know if it can be done? Is this Campy being annoying or PRO being awkward? Or is the LBS not trying hard enough?! Cheers!
PostPosted: Sat Feb 01, 2014 2:53 pm
Pro is made by Shimano.....Shimano and Campy are not compatible.
:smartass:
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sat Feb 01, 2014 3:44 pm
We need pictures. I wonder if the angle you want to achieve is too high up on the bar where the diameter begins to increase rapidly ... I can only speculate without pictures ... Did I mention we need pictures?
PostPosted: Sat Feb 01, 2014 3:52 pm
It is IME a Campy problem and common with a lot of bars. This sounds daft, I know, as it is likely loose as hell no matter how much you tighten it (again, common...) but carbon paste actually really does the trick. Be as liberal as you can with the application without it being "wet" when applied around the whole clamping area.
I apply more than needed in these cases, and then carefully with my fingertip smear it out just until it is "dry". You will still need to tighten down the clamps but usually nowhere near the harsch end-of-threads levels that you did before.
This all comes from experience and also reading the same thing multiple times on different forums.
The Shivenge
PostPosted: Sat Feb 01, 2014 5:41 pm
How large is the gap?
What about some Loctite retainer? (Not threadlock)
PostPosted: Sat Feb 01, 2014 6:24 pm
No problems whatsoever using Campy SR with Pro Evo's and this is my second build with that combo.
PostPosted: Sat Feb 01, 2014 9:19 pm
@DMF
gfk60 wrote:
....and there's not enough thread to tighten them properly.
Carbon paste wouldn't solve this problem if the facts are correct.
It sounds like the bikeshop is erring on the side of caution.
@gfk60
I think they aren't trying hard enough. They could use longer "T" bolts and / or longer clamp nuts to achieve more thread location. Titanium brake nuts (available in various lengths) can be used as clamp nuts.
PostPosted: Sun Feb 02, 2014 9:57 am
5 8 5, I speak from experience. Have had this exact same issue (as have others) and you could tighten that bolt with seriously unhealthy force, and the levers would still sit too loose on the bars. This actually happens from time to time (but seemingly, Campy is always the common denominator), and carbon friction paste actually helps.
The rest might be theory, but these are the real world proven facts.
The Shivenge
PostPosted: Wed Feb 05, 2014 8:40 pm
Ya have to wonder ... did you get a counterfeit (knockoff set) ? My guys have built dozens of sets up with this combo and no complaints.
PostPosted: Thu Feb 06, 2014 11:52 am
I run campy on my Pro Stealth evo no problems at all
PostPosted: Fri Feb 07, 2014 8:11 am
+1...it's not a Campagnolo problem, it's a where u r placing ur levers problem. EM3
______________
There are no new unread posts for this topic. Bar end shifters on drop bars
ericoschmitt
Tue Dec 05, 2017 3:13 am
ericoschmitt View the latest post
There are no new unread posts for this topic. SRAM HydroR shifters on compact bars
motorapido
Sun Nov 19, 2017 7:35 pm
motorapido View the latest post
There are no new unread posts for this topic. Retrofitting etap in to Campy 10 speed shifters
uraqt
Tue Jul 11, 2017 7:13 am
There are no new unread posts for this topic. Pro Stealth Saddle
misterq
Fri Jan 19, 2018 5:57 pm
misterq View the latest post
There are no new unread posts for this topic. Shimano Stealth EVO Pro seatpost, screws
split
Tue Jan 31, 2017 5:17 pm
split View the latest post
Users browsing this forum: Attermann, Baidu [Spider], Bing [Bot], jokersan and 37 guests
cron
