It is currently Sat Dec 16, 2017 10:20 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Wed Jan 22, 2014 12:40 pm
After excellent service from quarq in regards to my dead specialized quarq spider, my spider is winging its way back to me, they are also sending me a lockring tool so I can change my cranks over myself. Does anyone have these and know what wrench diameter I need to use it. I want to buy a wrench bit which will attach to my 9/16 torque wrench so I can install it properly.
Cheers
Andrew
PostPosted: Wed Jan 22, 2014 6:40 pm
Its on the order of 3" or so if I recall. I stick mine in my vise. I've got a crescent that works on it...a standard socket wouldn't work, because its not machined into a hex - it has parallel faces only. Perhaps a monster crow foot wrench could, but I doubt it. The issue is that you need to apply even pressure to it, or the tabs will jump out. If you do this multiple times, you can mar the tool / lockring to the point of it being unusable.
Also, you need to be careful when removing the existing spider - its pretty much a press fit. Pushing on the outside of the spider can damage it. I created a tool out of a PVC union using a dremel to clear the crank arm that works - 3" I believe.
There are no new unread posts for this topic. Shimano Lockring Removal Tool For Zipp 177 Hub
MrMojo
Sat Jun 10, 2017 11:08 pm
MrMojo View the latest post
There are no new unread posts for this topic. Campagnolo Lockring
3Pio
9
778
Sun Dec 18, 2016 12:41 pm
bikerjulio View the latest post
There are no new unread posts for this topic. SRAM 11/Ksyrium Pro/Lockring Issue
goldmine848
Sun Aug 20, 2017 6:26 pm
goldmine848 View the latest post
There are no new unread posts for this topic. Campagnolo 11 speed cassette lockring help
Sweetbabyj45
19
1173
Tue Jul 18, 2017 4:54 pm
Sweetbabyj45 View the latest post
There are no new unread posts for this topic. Do Campagnolo Routinely Supply Incorrect Lockring With Cassettes?
Valbrona
22
1577
Thu Dec 22, 2016 2:22 pm
wingguy View the latest post
Users browsing this forum: CamW, Google [Bot], jemima, Ticlimax and 36 guests
