It is currently Tue Jan 16, 2018 4:55 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Sun Dec 15, 2013 2:41 pm
Administrator
Is this the lightest solution if you replace the bolt with an alloy bolt and alloy nut?
http://www.amazon.com/Tektro-Front-Cabl ... B006GHDRYC
RESIDENT GRUMPY OLD MAN.
PostPosted: Sun Dec 15, 2013 11:11 pm
This one is lighter and seems like a better idea from an engineering standpoint.
http://www.amazon.com/Tektro-Hangar-Adj ... d_sbs_sg_4
PostPosted: Mon Dec 16, 2013 3:09 am
Less likelihood of fork chatter with the first hanger
PostPosted: Mon Dec 16, 2013 12:31 pm
Please don't use an alloy bolt on that cable hanger.
PostPosted: Mon Dec 16, 2013 1:05 pm
I'm sure he meant alloy adjuster........ changing the bolt just doesn't bear thinking about with all that leverage........
PostPosted: Mon Dec 16, 2013 7:20 pm
Two years ago I tried this:
http://shop.berner-bikes.com/drupalprod/Zughalter
and I couldn't believe I fixed the fork chattering on a easton ec90 fork after I tried almost everything. Now I have it on all my bikes (4). I couldn't spend my money better
PostPosted: Mon Dec 16, 2013 7:54 pm
Can you post a picture of your bike with this holder installed please? This holder looks interesting.
PostPosted: Tue Dec 17, 2013 11:37 am
I would also like to see that picture :)
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Tue Dec 17, 2013 2:20 pm
It just replaces a headset spacer. So won't work on mine. (Slammed stem)
I even had to get new forks to stop the juddering, and fit a crown mounted cable stop.
PostPosted: Tue Dec 17, 2013 4:27 pm
Administrator
Slammed too. To have the same bar height as my old bike I can only use one 2mm spacer. Did find a titanium bolt for the mount. When I get it in I will show original weight and what I tuned it down to, safely of course.
PostPosted: Wed Dec 18, 2013 7:18 am
Lightest solution I've seen is two-step hole through the stem.
Upper hole (top of stem) is large enough to take the housing. Lower hole (bottom of stem) is only large enough for the cable. This makes the housing 'stop' in the interior of the stem.
Total weight gain is actually a loss: you will only lose a gram or two from the holes.
PostPosted: Sun Dec 22, 2013 7:59 pm
http://www.concept2composite.com/products.html
PostPosted: Sun Dec 22, 2013 9:30 pm
@headwind816:
PostPosted: Mon Dec 23, 2013 3:39 pm
@vcnz - thanks for the pictures. That set-up looks really nice!
PostPosted: Tue Dec 24, 2013 4:28 pm
It doesn't get any lighter than removing material....
There are no new unread posts for this topic. Lightest crank + bb solution for a bbright frame (like the s5)
alcatraz
9
687
Wed Nov 08, 2017 5:03 am
prendrefeu View the latest post
There are no new unread posts for this topic. canti vs disc
stormur
39
2808
Tue Dec 26, 2017 9:04 pm
Multebear View the latest post
There are no new unread posts for this topic. OSBB to BSA - what's the best solution?
ak47
Sat Mar 18, 2017 4:31 pm
lovemyway View the latest post
There are no new unread posts for this topic. Sram Red 22 Lazy Rear Shifting Solution
Mr.Gib
Wed Oct 04, 2017 11:06 pm
asiantrick View the latest post
There are no new unread posts for this topic. Litespeed T1 hanger question
addictR1
Sun Jul 09, 2017 9:07 pm
addictR1 View the latest post
Users browsing this forum: Bing [Bot], dagex, ms6073, WorkonSunday and 3 guests
cron
