It is currently Sun Jan 21, 2018 3:55 pm
 Post subject: SRam Powerlink on DA?
PostPosted: Mon Nov 18, 2013 7:49 am
I'm building a bike for my wife with DA7800 group. Can I use the SRam power link with it or any other type of masterlink?
I've read some will cause the chain to skip forward. Any suggestions?
Thanks
Sent from my cm_tenderloin using Tapatalk
PostPosted: Mon Nov 18, 2013 8:46 am
Yes, used both Sram powerlinks aswell as the KMC ones multiple times on DA7800 (and other shimano chains) without problems.
This is my Bike. There are many like it, but this one is mine. Without me, my bike is useless. Without my bike, I am useless.
PostPosted: Mon Nov 18, 2013 11:17 am
Yes you can, but I found Wipperman Connex link easier to open because you do it by hand.
I have used both on a CN-7901 chain and I choose the second one.
PostPosted: Mon Nov 18, 2013 11:30 am
Have used KMC chainlinks with good results on 10sp 7900 chains. Easy to remove, harder to "pull in place".
Dead easy with a masterlink plier though which I strongly recommend - http://www.parktool.com/product/master- ... iers-mlp-1
PostPosted: Mon Nov 18, 2013 9:50 pm
The Park tool is great for removing KMC links. When they are new they are hard to remove without a tool. To get them to snap in place after installing, rotate the chain so the link is on the top run, lock the rear brake and step on the crank. It doesn't take much force. But make sure the pins are in place first.
PostPosted: Mon Nov 18, 2013 11:54 pm
If you need to open them, and don't have the pliers, just insert an allen wrench on either side of the link and squeeze them together.
PostPosted: Tue Nov 19, 2013 3:30 am
Thanks for all your replies. Guess the sram one is easy to remove without using tools?
Sent from my SGH-M919 using Tapatalk
PostPosted: Tue Nov 19, 2013 1:40 pm
+ 1 on the wippermann connex, it's the easiest to remove
PostPosted: Tue Nov 19, 2013 10:31 pm
Thanks.. bought the wippermann
PostPosted: Wed Nov 20, 2013 12:46 pm
I use a KMC missing link all the time on my Ultegra and DuraAce chains. Works fine, no problems. I hate the Shimano bullet link, PITA and not reusable if you have to remove the chain ever. I just keep a few missing links always on hand.
I did buy the Park MLP1 tool for removing the link. You dont need the one for closing it, that can be done by hand strength, pulling on both sides of the chain with a towel for grip I found.
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 6 ]
Shrike
75
12040
Thu Dec 14, 2017 7:12 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Sram red 52/36?
commendatore
Mon Jul 03, 2017 9:44 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Sram red leaver pin
SNUGSHIP
Tue Apr 18, 2017 11:00 pm
SNUGSHIP View the latest post
There are no new unread posts for this topic. 11-30T with sram force22 RD?
apricotwalnut
Sun Aug 13, 2017 3:15 am
alcatraz View the latest post
There are no new unread posts for this topic. Sram Etap
Jowwy
Fri Aug 25, 2017 1:32 pm
Jowwy View the latest post
Users browsing this forum: dricked, Google [Bot], Google Adsense [Bot], jih, raggi, tibikeboy, wallymann and 40 guests
cron
