It is currently Wed Jan 24, 2018 12:46 am
Post new topic  Reply to topic  [ 469 posts ]  Go to page 1 2 3 4 532 Next
PostPosted: Mon Oct 28, 2013 9:19 am
I have heard that a C60 is not far away maybe mid summer.
It will be a frame which will take electronic and manual set up.
I am going to wait and see what happens before I buy another c59 in a different colour scheme. :D
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
PostPosted: Mon Oct 28, 2013 4:25 pm
oh come on markyboy, you can never have too many C59s in different colours imo
PostPosted: Tue Oct 29, 2013 12:19 am
Should be soon anyway. C50 was 2003/4 IIRC. My dealer recently told me the differences between EPS and C59 were not enough to justify spending huge amounts on the latter and that I should just wait for the 60...
My EPS: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=72682
PostPosted: Tue Oct 29, 2013 9:41 am
I was told spring hence the price reductions on C59's
PostPosted: Tue Oct 29, 2013 12:22 pm
I might be wrong but havent they generally introduced the art decor bikes just before they released the next model?
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Tue Oct 29, 2013 11:57 pm
a C60 on an Art Decor paintscheme sounds delicious
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
PostPosted: Wed Nov 06, 2013 11:17 pm
Spring,Still lugged,still made in Italy...Press fit bb. :-(
PostPosted: Thu Nov 07, 2013 11:46 am
The 2014 C59 frame is now set up for both electric/manual groupset. I was surprised when mine arrived set up to take both as I had seen/heard nothing to indicate they were making this change for 2014 and when I ordered the frame you still had to elect between manual and electric.
Not a big fan of press fit BB, so if the C60 is going that way then it looks like I will be keeping stock of the C59 to keep me going !
PostPosted: Thu Nov 07, 2013 1:50 pm
How would you know, you haven't seen a C60 yet ... :noidea:
PostPosted: Thu Nov 07, 2013 4:10 pm
Can you post some photos of this dual use 2014 C59 frame?
PostPosted: Thu Nov 07, 2013 4:26 pm
Yes. I'd like to see it. I've not heard of any running changes like that. I suspect that will likely be the case however. And the pressfit bottom bracket. So that's two thumbs down so far. Only other change that I think might be made is in the fork and rear stay area. They could possibly add some clearance for the wider bigger tire wheel trend. I'm neutral on that one. So, if those things happen, and I don't have any info on it one or another, that would be two steps backwards and one sideways as far as desirability to me goes. I really hope they don't do anything super silly like proprietary aero brake placement etc.
Colnago C60 - PR99; Trek Koppenberg - Where Emonda and Domane Meet;
C59 Five Years Later
Trek Emonda SL Campagnolo SR; Special Colnago EPQ
PostPosted: Thu Nov 07, 2013 4:31 pm
http://www.bikeradar.com/forums/viewtop ... t=12944790" onclick="window.open(this.href);return false;" onclick="
mpower - there is not a lot to see and the frame is now built up, so there is even less to see !
The entry for the cables on the downtube is set up to take either mechanical or electric cables with little plug to cover the bits that are not used. There is a hole in the seat tube for a cable to the FD and a plug to cover it over if you use mechanical. For the RD there is either a small guide that you screw in under the RH stay if going mechanical, or there is an exit point at the rear of the stay if going electric (again supplied with plug if going mechanical - supplied in black and white so you can colour code your frame). By the BB there is a small shelf for the external battery - very much like the 2013 electric frameset.
It seems to have been done pretty well without lots of redundant exit/entry points - personally I would ditch the battery shelf and go for an internal battery but I guess that would be too restrictive at this point until external batteries become obsolete.
 Post subject:
PostPosted: Thu Nov 07, 2013 5:15 pm
Colnago C59 Italia 2014 frameset at twohubs.com - YouTube
PostPosted: Fri Nov 08, 2013 12:34 am
I think dual mechanical/electronic is a great idea. Wish my C59 was.
PostPosted: Fri Nov 22, 2013 2:24 pm
LOL- good call. The old OTT adulation for Colnago is alive and well!
There are no new unread posts for this topic. Colnago EPS or C59?
MattN
Mon Jan 22, 2018 5:28 pm
MattN View the latest post
There are no new unread posts for this topic. Attachment(s) Colnago C64 First Look
[ Go to page: 1 2 3 4 5 ]
Jitensha
60
7876
Sun Jan 21, 2018 10:25 am
fromtrektocolnago View the latest post
There are no new unread posts for this topic. Attachment(s) New Colnago
E90
Tue Aug 29, 2017 9:40 am
jin28h View the latest post
There are no new unread posts for this topic. Attachment(s) Colnago C50 or ?
nube
31
2669
Sun Jan 21, 2018 3:48 pm
wallymann View the latest post
There are no new unread posts for this topic. what's going on with Colnago
fromtrektocolnago
Sun Sep 17, 2017 3:27 pm
joeyb1000 View the latest post
Users browsing this forum: JS300 and 31 guests
