Upgrading - 7970 Di2 vs 9000 Mechanical...
by addicted
Upgrading from 7900 mechanical.
If the cost were similar, which would you choose and why??
Shop Wrench
by ianSWBB
If cost were the same, I'd go electronic every time - Have ridden both and there is definitely a difference in performance between the 2 - the electronic is precise every time and trims great when on the larger 5 sprockets of the cassette (I use those ones a lot!! but that's a legs issue, nothing to do with the kit!)
Following directly on - I'm not a good enough rider to notice the difference between the 10 speed Dura Ace (7900/7970) and the 11 speed Dura Ace (9000/9070) - Both good, but find I don't really need that extra sprocket - I know Shimano give tons of blurb as to how the 9000 series is improved on the 7900 series blah blah, but not that I could tell the difference!
Good luck
by Zigmeister
Electronic is lighter. Plus, who cares if you save $200 on a group set. Makes no sense to me personally to get a far superior group set in the 9070.
by gwilliams
If cash is no object I am sure 9070 is a great system. I will be changing from 7090 to 9000 pretty soon. I am indifferent about the 11th cog, I just like the simplicity of a mechanical group set, and having briefly ridden 9000 I think it seems spot on.
by pdlpsher1
Or you could consider the Ultegra 11 speed Di2. You'd get identical performance to the 9070 with only a weight penalty. Personally it's a no-brainer to go with Di2 if you don't mind the cost and weight inceases. With the new seat tube battery the weight penalty of Di2 becomes a non-issue. I'm currently running 9070 with the internal battery and I love it. I went from 9 speeds to 11 speeds and I agree with others that the extra gear (2 in my case) isn't noticeable. GL.
