It is currently Sun Dec 17, 2017 11:39 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
Which would you choose
Stick with current 1600 gram clincher wheel 33%  33%  [ 2 ]
Switch to 1100 gram tubular wheel 67%  67%  [ 4 ]
Total votes: 6
 Post subject: Wheel help
PostPosted: Sat Oct 12, 2013 4:35 am
Hi, so currently I have a set of carbon wheels that weigh 1600 grams and are clincher, and I have the opportunity to get a set of 1100 gram tubular wheels that are the same 24mm depth for an unbelievable price. Both have the same hubs so that is not an issue, would you stick with the clincher, or switch to tubular for the 500 gram loss. Also, the heavier 1600 gram clincher wheels look much better if that matters. I won't be doing any racing on them, just using them for the regular group rides and such, probably only average around 150-200 miles a week.
The benefit of lighter weight discussed in the below and MANY other threads
viewtopic.php?f=3&t=88913
 Post subject: Re: Wheel help
PostPosted: Sat Oct 12, 2013 1:25 pm
You will feel the difference, but for the amount of riding you do it probably isn't going to be that big of a deal to you until you weigh your bike. Plus the heavier wheels look better, and that means a lot!
Is it hilly where you ride? What do you average on your group rides? Distance? Elevation gain? Do you want to mess with tubes/glue?
Those are the questions that should dictate your decision.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sat Oct 12, 2013 3:40 pm
The lighter tubular wheels will make accelerations more lively and responsive but the wheels probably won't make you any faster. If your getting them on a screaming deal though, then go for it!
http://www.zencyclery.com
PostPosted: Sat Oct 12, 2013 4:11 pm
If they are really a good deal, just get them and ride both.
Report back.
formerly rruff...
There are no new unread posts for this topic. Wheel choice.
blueturtle
Thu Jan 26, 2017 1:36 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Jockey Wheel Help!
JScycle
Mon Jun 26, 2017 5:32 pm
2lo8 View the latest post
There are no new unread posts for this topic. Rims for wheel build
pickerd
Mon Jan 02, 2017 5:37 pm
pickerd View the latest post
There are no new unread posts for this topic. Attachment(s) RD-R9150 wheel removal issue
beanbiken
29
2267
Tue Mar 28, 2017 1:05 pm
ms6073 View the latest post
There are no new unread posts for this topic. Giant PR-2 Disc Wheel Weight
ThePessimist
Sun Oct 08, 2017 1:16 pm
Stickman View the latest post
Users browsing this forum: Bing [Bot], coriordan, CXrider, Delorre, Google [Bot], gzon, kookie and 38 guests
